Ok, I'm new to the board here, but I can see there is a real goldmine of experience and talent out there. I'm sure you've heard this one before, but I was unable to turn up anything on the search. Here goes...
I've got a '97 Explorer 6 cyl, automatic, 2WD with what Ford called a tow package when we bought it. Looks like a lower rear end ratio and a tranny cooler.
When I accelerate from a stop, with or without a trailer, and I either make a turn or catch a bump, I pick up a growl from the rear of the vehicle. I've only got 20K miles on it as I keep it primarily to tow a small travel trailer. The growl has happened since it was new, and only happens under a load as in rapid acceleration w/out a trailer, or heavy acceleration with teh trailer.
Anyone got a similar problem and found a fix for it. I haven't noticed any deficiency from it, but it is an annoyance.
Also, I indicated that it has a factory tow package. How come Ford, unlike Chevy, doesn't give you the wiring for trailer brakes. Helped a friend with his Suburban, and the heavy load wires were already there, as well as a lead to actuate the electric brake sensor. No so with Ford.
Thanks again
Thanks again
