- January 10, 2006
- State College, PA WE ARE... PENN STATE!!
- '07 Sport Trac Ltd V8 4x4
Hi all...
I'm posting this problem for future reference to any other ST owners out there who have had a similar issue. For my current setup just click on 'Black Betty' below.
A few weeks ago, I noticed a nasty vibration coming from underneath my truck. I took it into the local Midas shop for an oil change, tire rotation, balance, and alignment, and asked them to take a look around. They found numerous leaks (front and back), a torn boot (can't remember if front or bad) and a bad set of ball joints (no surprise). They didn't want to touch the leaks due to their own limitations, so they recommended another local garage, which I also trust ( I have had a couple previous experiences with them and friends have recommended their work).
Once at the second shop, they found that the rear drive shaft carrier bearing was in very bad shape, so they came back with a $1k parts/labor bill to replace that $800 for the shaft + $200 for the labor). I gave them the green light, and they replaced it. They also said that both front axles had some play and recommended that they also be replaced along with the control arms/ball joints. They said this would also take care of the the leaks that Midas had found in the previous evaluation. I gave them the ok to replace the axles and upper control arms/ball joints ...another $1600! After those repairs, they asked that I come in for a test drive just to see how it felt. Once I arrived, the owner showed me all my old parts and reviewed why they needed to be replaced. I'm surprised the carrier bearing lasted as long as it did, because it was just barely hanging on the shaft. The old front axles did have some play in them, so I acknowledged the explanation and took Betty for a drive down the interstate and back. To my surprise, the vibration was still present with absolutely no change whatsoever! I handed the shop owner the keys and told him that they did nothing to fix the vibration. His face just dropped.
So back to the drawing board.
Does anyone have the slightest clue as to what might be causing this vibration? This isn't just an annoying vibration, it feels bad enough to make me believe it's a serious problem.
Vibration characteristics:
1) It's definitely under the truck (can't tell if it's front or back ...seems to be in the middle).
2) Can't feel vibration in steering wheel or pedals.
3) Starts when accelerating and remains until stopped/parked.
What's been fixed/replaced/tried so far:
1) rear drive shaft
2) front axles
3) left/right control arms/ball joints
4) spin balanced all wheels
5) 4 wheel alignment
Other notes
1) They moved the front wheels to the back and back to front with no change.
Currently in process:
1) replacing noisy rear wheel bearing
2) replacing rear axle (they found it's leaking and has some play)
I'm into this nightmare for over $2700 going on $3k with very little hope of any resolution. I just want my truck back without any further hits to my savings!
Sorry for the lengthy post. I'm at my wits end!
1) rear drive shaft
2) front axles
Other notes
