Wanting to put 1996 4wd engine into 2000 4wd . Both are explorer | Ford Explorer Forums
Should be fine as long as they are both OHV engines.
No it won't be a direct swap. 98+ has an 8 bolt crank and pre 97 are 6 bolt. Also 98+ has different heads than earlier, not sure how much it would affect things.
Double check what 4.0 v6 you have, what does it say on the intake or engine cover?
