ahuggins6
- May 20, 2011
- New Boston, TX
- 1999 explorer 4.0 auto
im working on putting a 99-00 engine and PCM in my early bronco. I'm using a Moates quarter horse to bypass the PATS and delete the rear o2 sensors and emissions stuff. So far, The only programming I've changed is the PATS option.
However, I must be one of the few to try this with EEC Editor. I'm not sure it's getting the full programming. When I turn the key on, I can feel the PCM relay click on, almost simultaneously turning on the fuel pump relay, which goes off after 1 or 2 seconds. This is not long enough to tell if the pump is actually pumping (the line is open into a bucket in the right front fender well area) and the tank I built keeps the pump VERY quiet. I also can hear the IAB pop open about 2 seconds after I turn the key on.
I plugged a 1996 PCM in, turned the key, and almost immediately had fuel flowing.
So, the question, what happens when you turn your key on? Shouldnt the fuel pump push fuel immediately?
