jwv3
- January 22, 2008
- Delaware
- 92 xlt
I've been trying to figure out why my truck is idling at 1000 rpm's. I've searched the site and only found one or two posts that say it should be 650-750 rpm's. Is this correct for manual, 5-speed Ex's?
It isn't a rough or erratic idle, it is smooth and accelerates fine and settles back down to 1K all the time.
Here is what I have done so far:
New Idle air control installed today.
MAF sensor cleaned. (twice)
TPS set to 0.965 volts at closed throttle position (and verified 5 volts power side).
Checked all vacuum hoses one by one and by removing each and plugging the port. no leaks found.
Sprayed carb cleaner around base of intake manifold to check for leaks, none found.
Verified that the throttle butterfly is closing completely.
Any suggestions would be appreciated.
