What is the easiest way to remove the doors on an XLT? | Ford Explorer Forums
Jstcruz
Deltona, FL
97 Ex XLT & 84 Ranger
I know to take the bolts out of the hinges and the door comes off, what I'm unsure about is the harness going into the doors. Do I disconnect everything and drag it out of the door?
Any info is appreciated!
On the front doors there is a big black cylinder bolted to the door that the wires run thru. On top of that cylinder there is a 10mm (I think) capture bolt. If you put a socket on the bolt and turn it, it will push the two parts of the cylinder apart until they disconnect. Door and body are now disconnected electrically. I assume the back doors are the same, but I have never looked. Good luck.
Thats good to know! Thank you for that!
Now what about the back doors?
