93explorereb
- January 16, 2009
- Northeast
- 93/97 4.0 EB/5.0 XLT 4AWD
Greetings;
I am trying to figure out what is name of the item that is connected to the end of the frontal drivetrain shaft. It connects to the flange (6 bolts setup) that connects to the transfer case. It also is connected via a rubber boot/clamped to the shaft. However, the inside has lots of grease and large ball bearings. The other end of the shaft is your typical u-joint setup. Would I have to purchase the whole shaft, or is this item sold seperately. It seems to have separated from the shaft, whereas the clamped boot connection/attachment, is torn off. A new shaft is $300.00 plus dollars, and a used one is about $150.00. What say you? Thanks in advance!
1997 explorer AWD 5.0 V8 front diff 3:55 ratio 123,000 original miles
Best Regards
Best Regards
