micke_932
- March 21, 2007
This morning my Explorer 97 (SOHC 4 V6) refused to start, it cranked but no life at all, after som checking I noticed a cable with a small black component at the end, shaped like a U about 2x2x1 cm with a metal bracket with a hole (for a screw), this was hanging in the air behind the coil pack.
When I grounded the bracked on that thing I got it to fire again so I just used one of the mounting screws on the coil pack to get it grounded and then it started fine.
The problem is I cannot figure out where this thing should be originally, I do not find any holes or anything but it is possible it is somewhere behind the coil pack, I will remove it tomorrow and have a look.
If any one has a clue to what this little thing is it would be nice to know, there are some number on it but it was a little to dark to check them out today, I will do that also tomorrow.
I am not sure where the cable is going, it goes down behind the coil pack so I have not found the other end yet.
