Wow... now there's a question. OK, the obvious part is the brake lines..... a couple to the master cylinder, probably via the proportioning valve and one to each wheel.
Electrical/electronic connections to the wheel speed sensors, powers and grounds and likely a few places I'm forgetting.
I don't know if you've experienced the "ABS shuffle" before, but this is the gizmo that makes that catrwaulig and makes your foot feel funny in hard braking on iffy surfaces.
As with anything technological, the early ones are crude compared to the latest offerings...... the old learning curve thing (don't forget, you Yanks went to the moon with less computing power than some wristwatches have now).
Your second picture is the EGR valve. It dilutes (NOT "leans out") the intake charge to reduce combustion chamber temps thereby reducing the formation of oxides of nitrogen (NOT nitrous oxide). It's these oxides of nitrogen that react with sunlight and give some cities that brownish "dome". Reducing CC temps (and combustion pressures) also helps to reduce engine ping.
Earlier 4.0Ls did require one as they met EPA guidelines without it. As standards get tougher and technology changes with each passing year, we see the addition/deletion of various components.
