ETHACK
- April 17, 2020
- nv
- 2001 X SOHC 4x4
Yea that sounds better, will have to order the leak/seals, sounds pretty simple and thankfully both are easily accessible , and will switch to synthetic at 5k, right now oil change every 1k, except 1st at 500, would anyone know the part# or ??? Like Koda will be adding a pre oiler this fall, M1 is what I'll run as well just like other vehicles. Just stinks that leaks on rebuilt motor, but at least easy fix, will keep posted and thanks again guys!!Do not switch to 10W40 on a SOHC, even if you do it will still leak. The only way to fix it is to remove the bolt, replace the washer/seal with some RTV under it.
