What should I gap my spark plugs to? (SOHC) | Ford Explorer Forums
Steeda90GT
Central NJ
99 Sport
So I'm finally deciding to do my plugs. What's the factory gap spec? Any recommendation on setting a better gap (for mpg??)
If I recall it calls for between .055-.057 or .054-.057. I usually just try to get it in the middle about .056.
It says in the manual towards the back.
Edit: Actually those values I gave you is for the OHV engines. The SOHC may be different.
I would also change your wires.
check the under hood sticker
Thanks! I already did the driver's side, now time to tackle the passenger side :confused:
