What size fuel injectors are in a 96' 4.0L OHV? | Ford Explorer Forums
fastcougar
Kearnysville, WV
02' Mountaineer - V8 AWD
What size fuel injectors are in a 96' 4.0L OHV? I called around and from what I gather, they are 14# ... that seems awefully low to me ... is this correct?
They are 19# injectors. They are sufficient for most power mods.
Sure it didn't change between 96 and 99? Like I said, I was told 14# ... was I told wrong or did it change?
It may have.
I'm not 100% sure, but I thought they were 19 pound in 1996 also.
19lb
All the v-6s use 19lb injectors as far as I know. The fuel systems changed in 98 so if the injectors are different the break would be with the returnless system I would think.
So 19lb injecters is the answer- same as the 5.0 mustangs
The 19 lb injectors should be good for around 230 hp BTW, so unless you have a really built engine, really built engine a switch to larger ones wont get you much FWIW.
