What's The Correct Transmission Filter? | Ford Explorer Forums
Diesel Tom
Stone Mountain, GA
2007 Ford Explorer
I've decided to do a filter and filter change on my 2007 Ford Explorer, 4.6L engine, 6R60 transmission.
I've seen two different filters listed for this transmission by major parts web sites:
1. Motorcraft FT160 (7L1Z7A098AA) with a smooth bottom surface.
2. Motorcraft FT171 (7L1Z7A098A) with an intake pipe on the bottom.
My transmission pan has a projection on the bottom (not a smooth bottom).
Which is the correct filter?
I had thought that all 6r60 trans had no sump and therefore used the FT160 filter. That's what mine uses.
If your pan has a "circular" sump that is about 1 1/2 to 2" deep, then you need the FT171 filter which has the pickup tube that extends into the sump.
I figured it out. The parts source I was using listed three filters which all said "from 12/04/06." All of these filters show the pickup tube. My car was manufactured in January 2007.
So the FT171 is the correct filter.
