wheel problem | Ford Explorer Forums
wheel problem
eterhaar
My 95' Limited thumps going down the highway. It always seems to be the left front wheel/tire. I have had the tires rotated and all wheels aligned several times to try to correct the problem. What could be the problem? Bad hub? Bad wheel? Is there an easy fix?
thanks for your response.
Did you have the wheel balanced? Check and see if the metal weight on the wheel fell off.
Yes, I forgot to mention that I had all wheels balance during each of my various tire rotations and alignments.
Could be a bad ball joint. Also, a little teflon patch on the torsion bar wears off and that will clunk when you hit bumps and things!
