Wheel Spacers? | Ford Explorer Forums
Wheel Spacers?
NWExplorer97
Pacific NW, WA
97 Explorer XLT
Can anyone explain the difference using (if any) 1" center centric wheel spacers or 1" deeper off set wheels?
Obviously I'd like to widen the stance with my 31x10.5s. I know some say the wheel spacers can cause premature wear on the bearings, etc. While others say they've had them on for years with no additional wear. It seems to me that the 1" spacers or 1" off set wheels would put the same load on the bearings, etc. I'd prefer the stock 7" wheels for 2 reasons, first $, second when I lower the air pressure for mud and snow I've had wider wheels loose the bead seal and resulted in flat tires.
Curious to hear what others have to say.
I'm pretty sure the only difference is the extra 20 lug nut's you have check once in awhile :):thumbsup:
And the extra weight...
might be more money but rims are the safest way to go. just got some with 3.75 backspacing and made a huge difference. got 33x14x15 and i clear with some trim job on the fenders
