bllk665
- June 19, 2011
- Woodstock, Ontario / Playa Del Carmen, Mexico
- 2002 Explorer XLT 4x4
It's time to replace the axle bearings on my 2002 Explorer 4x4 with 150,000 miles. The 'serpentine' test indicates noise from passenger side bearing is worse than drivers side, but replacing both at the same time makes sense to me.
There is no apparent noise from the differential or elsewhere in the driveline.
While replacing bearings, under what circumstances would you recommend replacing axles?
Can axles be 'refurbished'?
