Where 2 get cat back | Ford Explorer Forums
wpurple
CT
97 Explorer
Does anyone know where I can get a "off the shelf" cat back exhaust for my 97 Sport OHV? All the ones I have seen is for either the 4 dr or the 2dr OHC.
Thanks,
Kurt
Just go to a local muffler shop and have them make you a system. It will end up cheaper anyways.
Hi Alec,
I tried a few in the area and was told they can't create the bends around the axle.
Comments?
Thanks,
Kurt
Thanks,
Kurt
I had an exhause shop custom make mine for $200. Looks and performs great.
Are you asking for a dual exhaust? If so, then it is going to be difficult to route the driver side pipe. If you only want one tailpipe in the stock location, it should be no problem. They may think you want Mandrel bends. They help, but aren't necessary. If you get 2.5" pipe w/o Mandrel bends, its about the same as a 2.35" pipe in the curves. That diameter is plenty good. In fact, I have a 2.25" pipe w/o mandrel bends, and it works very well for me.
If you just want a single tailpipe and they tell you they can't route it properly, tell them they're full of it and ask them where they think the stock pipe goes.
