Where to buy Nitrogen | Ford Explorer Forums
1997XLTRollover
1996 AWD 5.0
Hey guys I'm not sure this is exactly the right place to post this but it probably gets the most traffic here. Anyway does anyone in the NJ/PA area have any idea where to get a Nitrogen bottle refilled? I have one and want to fix my EVAP system by smoking it, but I can't find a place to buy Nitrogen locally. The only place I found is an hour away from me and only open M-F 8-5 when I'm working so I can't get over there.
Welding shop should have it.
Try a cheap party fog/smoke machine, put a hose over the vent and reduce the hose down to the size you need.
Yep, any welding supply or hvac supply house should have exchange cylinders.
Getting your own bottle re-filled will limit things but even then, larger welding supply houses should be able to accommodate your needs.
Ok thanks guys I'll have to find a local welding place.
