Which fluid to use for the diff & transfer case? | Ford Explorer Forums
Jason94sport
FL
Sold
For a 94. Going to change the lube in the front & rear diff's & the transfer case. What is best to use? Should I just use what the manual states? Are there better ones out there?
Thanks
I switched up to full synthetic in mine and can notice a difference in fuel economy and smoothness - especially when the temps drop.
Use factory standard gear oil (synthetic) in the diffs and a Dextron III equivalent in the T-case. Don't put regular oil (gear oil - or motor oil) in the T-case!
Like ^^ glf said.
Dex III for the t-case. The trick is getting it in there without making a mess! And, synthetic diff lube :thumbsup: :thumbsup:
i use a pump that I got from the auto parts store... It is intended for axle lube, but it works for anything. Costs around $5.00 and pays for itself with the first change over. :thumbsup:
Need some more help here. I looked in the manual & it says to use API GL 5 S SAE90 gear oil. When I went to the store I saw different kinds of 90 oil. Some were 80W-90 some were 75W-90, 85W-90, high performance, & heavy duty. Which one would I use? Also is all gear oil synthic? I saw a bunch of brands there but none of the bottles said it was synthic or not.
the bottles will say syntehitoc on them if they are synthetic, otherwise they are regular oil....sae90 is straight weight.. the others are all a slight variation..... as long as its gl5 and still in the 90 class, it should be fine.....
^^^ Jimabeana is correct...
Gear oil that is syntetic will definately say so. The factory wants you to run a 90 weight gear oil of a specific specification in the axle. Most oils that you get will meet or exceed that spec, especially synthetics.
The multi-range oils (technically multi-viscosity) will have certain chemical properties built into their formulation that allow them to act like the lighter weigh oil when cold and the higher weight oil when hot.
As an example, people used to switch up the type of oil that they ran in their engines in hot weather. If the manufacturer called for SAE 30 or 10W30 for general use, some would go up to SAE 40 or 10W40 for hotter weather and SAE 20 or 5W20 for colder weather as the lighter weights are "thinner" (not really, but that is about the best descriptor of how they act) and flow out easier when cold, and the heavier weight oils will remain "thicker" or retain their consistency better when hot.
In minus 20F temps, a 90W gear oil is about the consistency of Karo syrup - and it doesn't do much to lubricate your gears until it warms up enough to flow. It can actually almost stall out the vehicle on a cold start becasue it simply does not flow - so most folks in cold weather climates use a 75W90, which will flow in cold weather like a 75 weight oil, but lubricate under stress or heat like the 90W. Same goes for gear oils that are 75W140 or some such formulation - they can take hotter running than the 90W oils.
With synthetics, though the numbers are simialr (75W140) they will actually flow BETTER than 75 in cold weather (it takes something like -80 to even start to thicken up the syntetics) and they will also take the heat better that a 140 will, but becasue they are so "free" in their pourability, they also lessen friction internal to the gearset - improving economy, etc.
So, find some oil that meets or exceeds the manufactures level - preferably synthetic (try another parts store) and you'll be happy and still be in specs for oil.
You can also tell by the price. Dino oil will be cheaper than synth. I used to use Mobil1 gear oil in my diff and tranny when I was racing. It's pricey but I NEVER had a failure (well worth the extra $$$).
Ok so I should be ok getting 80W-90? Or 85W90? It doesn't go below 45 at anytime here in South FL.
So will the synthetic 75-90 have better economy MPG than the synthetic 75-140?
My Manual recommends one weight for the rear and another for the front. I was thinking about synthetic 75-90 for front and rear to see if I can free up some MPG's.
What do you folks do?
I'd say go for the lighter weight stuff for max mileage.
Check out Aldive's thread posted earlier in this thread. He is the mileage guru - whatever he is doing is likely the best there is...
he's probably using the Mobil Synthetics.
Mobil seems to be one of the best around in Synthetics
I already have run mobil 1 synthetic for the pas 80,000 miles in the crank. LOL. But... Im not sure that Mobil synthetic diff oil is the best here.
Thats funny. I saw a post of his on bobistheoilguy.com forum asking about tranny fluids for better mpg. LOL. But yeah, I will give him a quick pm.
Al's either using Mobil or AMSOIL can't remember. I use AMSOIL 75W-90 in the front and rear diffs. I've improved my mileage a little; of course I also have synths in the trans, etc. and all of it together has helped my mileage a little--so it's hard for me to attribute the mileage increase to any one thing.
Sort off topic: Has anyone seen one of those transparent rear diff covers? Kind of neat but I won't do it for my truck. Still, it would be neat to see in there all the time.
For the diffs, I would use the visosity the manual suggests, in fact sometimes there is a tag on the diff with what wheight oil to use, and then go either synthetic mobil 1 or redline or royal purple, they are all great brands.
All the manual for my 94 says is SAE90. Doesn't say anything about the other number 75W, 80W, 85W,. I picked up some full synthetic Mobil 1 75W-90.
Thanks for the help
