Sandy Keller
- June 20, 2018
- Prescott AZ
- 2017 Ford Explorer Sport
I have the same issue with my 2017 Explorer and so far, it only seems to happen when the AC is on. I searched Google for this issue and found an older thread on this forum. I’ve copied and pasted three of the responses below. Funny how this issue has been going on since 2005 or earlier! I had an appointment with the dealer tomorrow morning, but canceled it earlier and decided to do my own research. They told me they had no knowledge of what the sound could be.
1. I have had this loud intermittent "whooping" noise coming from the back of my 2005 Ford Explorer. Everytime I took it into the dealer, they couldn't find the problem. If it's making this sound, you need to replace the HVAC Heater/ AC Module in the back. Go to www.fordparts.com and plug in your make, model to order. Unfortunately, the part is expensive ~ $250. It will be delivered to your Ford Dealer. You can have your Ford dealership fix it. They will charge ~ $800 including the module. If you are mechanically inclined, you can fix it yourself. Here's how:
2. The simple solution to this problem is to evac and refill freon. The Explorers with rear A/C hold a huge amount of freon 1.33kg. The noise is coming from the expansion valve, I believe due to a small lack of freon in the system. Almost a month has passed with out a reoccurance where as it was a daily event.
3. its the ac system. its the anti ice thing, i cant remember if a reprogram or a new expansion valve. fixes this issue, i think its a reprogram of the pcm, how it controls the ac compressor.
