Cedar
- November 2, 2010
- Portland, OR
- '94 XLT
This has all been discussed to death, never definitively, so I figure its about time for an update of musings on the topic. Trying to replace my fan blade, it's all cracked, reading all the threads about fan blades/fan clutches etc., keep seeing it mentioned that we lose power in the winter from the clutch fluid being more viscous.
The disclaimer is, I'm stuck on fan clutches, don't bother me with electric wirey do-dads and ohm-meters.
Why not have a lower CFM fan in the winter, up to and including trimming down a cheap dorman fan and changing that in with the snow tires? The sensible thing would just be to have an equivalent unadulterated 9 blade for winter and the 11 blade motorcraft-tornado-vortex-whoopty-do for the spring/summer. I'm looking at highest highs of 59F, ave high of probably 45 through the next few months. My engine runs cool during the summer, I just replaced the thermostat and sender and I can't get above N on NORMAL. I wouldn't mind if it ran a little warmer. What pitfalls am I not thinking of? I haven't been up to the mountain recently, but I've never had any troubles doing that even in the summer.
If you're still reading and have an idea of where I could still by a top quality fan without paying the $82.80 my dealer wants for the blades, that's great, I couldn't find anything solid in the forums. Even a recent part number since #8600 isn't even recognized by fordparts.com when I use it. Local options are Murray and VDO.
Just an observation that I hope others have observed or can set me straight: I've read all kinds of accounts of how the 1991-1994 fan clutch should feel cold. I tried twenty today from cars in the salvage yards, they're all stiff and only rotate a few blades worth of rotation at most. That's what mine does, except they do it slightly differently and by the end it felt like I was testing mangos for ripeness in how little difference there was between rotational resistance of used clutches.
Last observation: the crow foot tool part of the W80585 ford clutch tool kit is absolutely diabolical. I spent an hour trying to get that thing to stay on the water pump pulley bolts. As little space is there is, there's more than enough room for it to slip off once I'm able to get any kind of tension on the assembly. I tried for an hour. I might try for a few more minutes, but after fiddling around with that ridiculousness, I think I'm gonna drill and tap it for a handle. Were it a wider tool like I see images of other professional grade crow -foot tools, it would be much thicker and not just dangle and dance all around the end of my socket wrench. :roll:
