Pokface
- September 25, 2003
- hills of TN
- '95 eddie B 4x2
Hi thanks for looking
heres the link
http://www.adireaudio.com/Merchant2..._Code=AA&Product_Code=9010&Category_Code=9000
The parameters are:
Fs: 48 Hz
Qms: 6.2
Qes: 0.72
Qts: 0.66
Vas: 14 liters
Sd: 140 cm^2
Xmax: 8mm one way linear, 12mm one way peak
Re: 3.5 Ohms
Le: 0.45 mH
"A nice little performer! True 4 Ohm impedance, run it with a clean 30-50W per channel and you'll have great results. "
Just want something to replace my blown stocker. If the 4ohm load is a problem can I just dial down the gain on the head unit to stay safe?
heres the link
The parameters are:
Fs: 48 Hz
Qms: 6.2
Qes: 0.72
Qts: 0.66
Vas: 14 liters
Sd: 140 cm^2
Re: 3.5 Ohms
Le: 0.45 mH
