Wind noise on 2010 | Ford Explorer Forums
Wind noise on 2010
Chris JL
2010 Ford Explorer
I got a 2010 Explorer xlt v6 . Im experiencing a steady amount of wind noise coming from the passenger side front door when i go 40 mph or more. The noise seems to be coming from the gap in between the of the door and the body and the weather stripping looks good . Any one know of a good fix ? Thanks
I posted this previously and don't know whether it worked for that questioner or not, but I will repeat it here:
Years ago, a body man showed me how to align the top portion of a door with the body. Place a dollar bill between the door and the "A" column, close the door, and check and see if it will slip out with little or no resistance. If not, continue around the door until you find where this happens. Once you have determined the area, lower the glass (don't forget that part) and, with the door open, place your knee on the panel just below the glass area and pull the top of the door toward you. It doesn't take much. Recheck with the dollar bill until you determine that it has been corrected. Raise the window and go for a test drive. By the way, you can use a five, ten, or twenty with the same results!
