plumcrazylx
- August 2, 2006
- GF, ND
- 98 E/B
First off, my explore is a 98. This is kind of a weird problem because the colder it gets outside the worse the problem becomes. When I go to lower the window it acts like it rocks in the window channel. Its like the front part wants to go down and the back does one. If I hold the switch they will go all the way down. If I let off the switch when it happens, I can pull the back of the glass down in line like it should be, then it will go down fine. It does this on both the front does only, not the back 2. I've never had the door panels off so I don't know what it looks like in there. I can only think there must be some plastic piece or something worn out in there. If someone had a pic of the door panel off that would be great. Any help would be appriciated. Like I said, when its warm out it does not do this, only when it turns colder.
Thanks
Ryan
Thanks
Ryan
