Wiper blade motor making a screeching sound... | Ford Explorer Forums
PPro
Whitmore Lake, MI
'02 Sport
Its not the wipers themselves, it sounds like the motor. It does it randomly, and eventually stops and starts again.
Any ideas on how to fix it? I've never taken it apart before, so I have no as to how these things work.
Thanks.
12 views, no ideas?
Howdy, neighbor. Here's the process from the shop manual:
SECTION 501-16: Wipers and Washers 2002 Explorer Sport/Sport Trac Workshop Manual
REMOVAL AND INSTALLATION Procedure revision date: 01/17/2002
Windshield Wiper Motor
Removal
Disconnect the washer hose from the LH washer jet nozzle.
Remove the cowl grilles; for additional information, refer to Section 501-02.
Unsnap the wiper motor clip from the RH wiper mounting arm and pivot shaft.
Disconnect the RH wiper mounting arm and pivot shaft from the LH wiper mounting arm and pivot shaft and move both away from the windshield wiper motor.
Disconnect the electrical connector.
Remove the ground strap nut and position the strap aside.
CAUTION: The internal permanent magnets used in the windshield wiper motor are made of a glass-like material. To avoid damaging the magnets, do not strike the motor with a hammer or any other object.
Remove the windshield wiper motor.
Remove the stud bolts.
Remove the bolts.
Installation
Install the windshield wiper motor.
Install the stud bolts.
Install the bolts.
Install the ground strap and nut.
Connect the electrical connector.
Install the wiper mounting arm and pivot shaft arms to the windshield wiper motor.
Install the LH wiper mounting arm and pivot shaft onto the windshield wiper motor crank pin.
Install the RH wiper mounting arm and pivot shaft onto the wiper motor crank pin.
Push the retaining clip until it snaps into place.
Install the cowl grilles. For additional information, refer to Section 501-02.
Connect the washer hose to the LH washer jet nozzle.
Install the LH wiper pivot arm. Refer to Wiper Pivot Arm—Front in this section.
Adjust the LH wiper pivot arm. Refer to Windshield Wiper Blade and Pivot Arm Adjustment in this section.
Now, with all that in mind, are you sure it's not the wiper blades? Maybe one of the pivot points on the linkage?
Oh, and removing the cowl is simple: Remove the wiper arms, then remove the single screw in the center (the right edge of the driver's side cowl piece). Then, pull up on the pieces to release the slips, driver's side first.
Good luck!
-Joe
Here's a suggestion for you. RainX sells a product that you add to the washer fluid and it's supposed to help keep rain off the windshield during light rain. It is cheap and seems to wax the glass - making the wiper blades slide over the windshield with much less force. Wheither it's the blades or the motor, the lubrication could help stop your problem - and it mades the wipers work better than you'd ever expect them to work. My blades used to chatter - now a few teaspoons of this stuff and they slide smoothly and are very effectively cleaning the glass at the same time.
Dennis
