Wiring Questions | Ford Explorer Forums
Wiring Questions
newbz
Albuquerque, NM
91 Custom
I am wondering what I need to do exactly about the factory stuff if i'm going to be running the 4 door speakers and my box from amps and i'm getting the signal from the HU. Can I just snip the wires and rip out the factory amps? Both amps are receivng the signal via RCAS so the HU won't be pushing anything also anyone have tips on running new speaker wire to the doors thanks
so your wanting to externally amplify the door speakers, and run sub(s).
Pretty much what i would do is.
figure out what wires from the back of the cd player go to each speaker, then cut them. run the speaker wires that would have run to the door speakers to where ever you are going to mount an amp. i only suggest this because rewiring the speakers one at a time from each of the doors is a PITA and this is much easier. then simply hook them to your amp.
if your feeding the signal to the amp via RCA's then it won't matter...
Tip
if you are running your stock speakers in the doors you really don't need to amplify them...they sound good with the 15-20 watts your headunit puts out.
hope i helped ya
ryan
