stillmarried
- May 14, 2015
- South Dakota
- 2017 ExplorerLimited 3.5L
Removed the front tires/wheels and found Zerk grease nipples by the front upper wheel hub areas, used my grease gun to fill the grease nipples, all went well.
When I
I then removed the rear tires, I found Zerk grease nipples by the rear wheel hubs, (see picture), however these Zerk grease nipples are a larger size than the front wheel area Zerks. I measured 5/16" in diameter on the rear Zerks, and my standard grease gun will not fit over these Zerk nipples. I tried to find a grease gun that had a larger adapter to fit over the larger Zerk grease nipple but no luck. Any suggestions on where I can do more research to steer me towards getting these fittings lubricated?
