Explorer90631
- August 7, 2006
- La Habra, CA
- '96 Explorer XLT V6
My explorer 96 XLT 4.0 has had a DTC P0420 for some time now. Smog check is required in a couple of months, so I need to fix this by then...no money to take it to a mechanic for now.
We connected a borrowed OBD2 tool and retrived the following:
DTC P0420 Catalist System Efficient below Theshold (bank)
live data @ idle
Cal load: 28.4 %
STFT B1: from -7 to 10 (%)
STFT B2: from -7 to 10 (%)
Eng RPM: 800
Spark Adv: from 8 to 12
MAF(lb/min): 0.664
TPS: 18.8 %
O2S B1 S1: from 0.065 to 0.725 (v)
O2S B1 S2: from 0.065 to 0.67 (v)
O2S B2 S1: from 0.055 to 0.8 (v)
What information can we get from this data?
Also, per a mechanic comment, once DTCs are reset, the compuer will read it again after driving the truck around 35 miles. A couple of times this is exactly what I noticed, but the last time, when I had to clean the ICV due idle issues, erased the DTC again. But after that, the check engine did not came ON around the 35 miles, but after 100 miles..I wonder why...does this ICV has something to do with this?
Do we really need to replace the cat or O2 sensors?
Any help will be greatly appreciated
live data @ idle
Cal load: 28.4 %
Eng RPM: 800
MAF(lb/min): 0.664
TPS: 18.8 %
