Serious Explorations Ford Explorer and Ranger Message Board
#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
Searches ExplorerForum.com Only
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Anti Theft Light Flashing On Dash , Car wont start.
Reply
Thread Tools
Old 02-10-2010, 10:15 PM   #21
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
don't recall seeing anything from you on what the anti-theft light is "saying". Might help with diagnosis.
budwich is offline   Reply With Quote
Old 02-10-2010, 11:25 PM   #22
Paul1967
Apache Junction Arizona
00 Ranger
Vehicle Specs
Quoted: 0 Post(s)
yep I'm using the original pcm, original wiring harness all the original sensors, and injectors all of which worked on the old engine, the old engine had a rod and wrist pin that were slapping and would not maintain oir pressure which is the reason for the swap. I didn't expect to have this other problem. I've done many many engine swaps in the past and never had this kind of problem except on a 2002 toyota camry which I didn't have to make run just swap engine and tranny.
Paul1967 is offline   Reply With Quote
Old 02-10-2010, 11:35 PM   #23
Paul1967
00 Ranger
Vehicle Specs
Quoted: 0 Post(s)
anti theft light is blinking really fast when the key is in the on position
Old 02-11-2010, 12:21 AM   #24
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
thanks... not good... if I understand you right... when you turn your key to on... the theft light goes from just ... slow pulsing to really fast and never goes out or solid (then out). Sounds like you could have a module issue... however, perhaps your pickup on the ignition is a problem... it could be just coinincidence that it happen during the motor effort. Just a thought.
Basically, if you don't get the light out, forget trying to start (just do your key in on for testing is all you need)... you are just wasting your battery, your starter and even your engine. There are threads on the pickup stuff that you might check before "fighting" the ford parts department on the module... I too have trouble getting the dealer to find parts for their own vehicles (GM seems to have a easier time with their makes... maybe more practice).
Old 02-11-2010, 07:23 PM   #25
Paul1967
00 Ranger
Vehicle Specs
Quoted: 0 Post(s)
I took it to the dealer two days ago and thats what they said was it was a module problem and according to them they can't get it. So now what I am doing is finding a way to by pass it there has to be a way without spending anymore money. Its just a manner of finding the right wires and running then to ground so that the injector drives are grounded which is what the problem is. Everything else works it cranks I have spark and there is fuel in the fuel rail at the right pressure. just have to get the injector drivers to do their thing.
( Join the Elite Explorers )
Join the Elite Explorers for only $20 a year
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose and fix problems yourself, and learn which modifications really work without having to experiment on your own. Elite Explorer members can change the forum "styles" to eliminate most ads, including the blue underlined links, and no ads on photos. Other benefits include the ability to store 1000 Private Messages, add your own avatar to your posts, upload photo attachments directly to your posts and to our Photo Gallery and more. Join the Elite Explorers today. Your support of the forum is greatly appreciated.
Old 02-11-2010, 07:46 PM   #26
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
PCM fires injectors
The PCM controls the energizing of the injectors. Each injector has a dedicated pin on the PCM that grounds the injector at the appropriate time for the appropriate duration. If you wire the injectors to ground they will be permanently energized and your engine will not run due to an excessively rich mixture.
I searched quite a bit for the thread I remembered reading about deactivating PATS but couldn't find it. There's a wire or jumper that's used on the assembly line. If it was easy a thief could do it and defeat it's purpose. All I could find was by flashing the PCM with a custom tune.
2000StreetRod is offline   Reply With Quote
Old 02-11-2010, 09:13 PM   #27
Paul1967
00 Ranger
Vehicle Specs
Quoted: 0 Post(s)
Yeah I have searched all of those too and then some. From what I understand from the ford mechanic I have to find the starter interupt relay and ground the light green and purple wire, but I'm starting to wonder if hes fibbing or if the relay exsist cause I havn't been able to find it. I'll keep trying sooner or later I will get it and the lady that the truck is a gift for will finally get it.
Old 02-11-2010, 10:25 PM   #28
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
I doubt that it a "starter associated wire" if there is a "wire around" method. Me thinks there is a "plug terminator" that might do something for you... but that is just a guess as the theft module "talks" to the system with more than just "grounds".
Old 07-27-2012, 09:12 PM   #29
showpony2010bc
sioux falls, south dakota
2000 explorer
Vehicle Specs
Quoted: 1 Post(s)
ok guys.. my turn to contribute.... I just went through this same problem with my 2000 explorer... damn anti theft light blinking, not starting.... after spending $350 at the local dealer and not fixing the problem I got mine fixed... It was a simple electronic relay switch. under hood, drivers side.. relay # FOAB-14B192-AA about 1"square relay..
repair relay part # listed as: FOAZ-14N089-A about $20 for the relay...
works perfect now.... what a headache.... perfectly maintained, but wouldn't start because of a faulty relay switch... needless to say the original $350 was money thrown away for nothing...
repair sheet states: NO START. THEFT LIGHT BLINKS RUN SELF TEST. NO COMMUNICATION WITH PCM. TEST PCM POWER & GROUND CIRCUITS. NO VOLTAGE PRESENT AT PCM CONNECTOR. PCM POWER RELAY STICKING, CAUSING NO START CONCERN. REPLACE PCM POWER RELAY, RUN SELF TEST AND REPAIRED VERIFIED...
hope this helps someone else and eliminates a great deal of unnecessary headaches..
good luck... shwpony2010bc
showpony2010bc is offline   Reply With Quote
Old 07-27-2012, 09:20 PM   #30
showpony2010bc
2000 explorer
Vehicle Specs
Quoted: 1 Post(s)
just an update, the original repair was for pats module, passive anti theft module.
supposedly they replaced that and fixed the problem... problem wasn't fixed.
From now on I'm going to ask for the old part when I get anything replaced... don't think
they replaced the pats module like they said they did...
Old 09-07-2012, 12:44 PM   #31
christopher t
Amarillo
2001
Vehicle Specs
Quoted: 0 Post(s)
Thanks. Good info. I'm having the same trouble but intermittently. Sounds like the relay is the likely culprit.
christopher t is offline   Reply With Quote
Old 09-09-2012, 12:30 PM   #32
heyscuba
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by robertoa1a View Post
Disconnect the battery for 10 minutes or so. The alarm got confused.
you are a genius,... and you saved me a lot of money because this worked for me,....!!!
heyscuba is offline   Reply With Quote
Old 02-11-2013, 10:59 PM   #33
SteFin
nashville tn
99 Explorer
Vehicle Specs
Quoted: 1 Post(s)
There's a youtube video haven't tried it but involves fooling pats so you could try it to determine if its pats here's the link
How to make a cheap transponder key bypass
If you are able to see this message it means that you don't have flash installed or that the video server is down.
SteFin is offline   Reply With Quote
Old 07-14-2013, 08:10 PM   #34
coolbreeze48
:amlt, north carolina
97 XLT
Vehicle Specs
Quoted: 0 Post(s)
I have a 2000 ranger with a rapid flashing theft light, starter won't work, jumped starter relay to make starter operate, but still won't start because fuel system is also deactivated. Is there any place to find a wiring diagram of the PATS system. I have looked all over the net and have had no success. would like to bypass the whole system if possible but from what I have found that can't be done due to the ECM control of the starter, fuel pump and the injectors. guess the only option I have is to take it to the dealer which will require it to be towed about 15 miles. tried a number of ways to reset it but to no avail. anyone have a sure fire way that I can use to get the vehicle cranked so that I could drive the 15 miles rather than have the truck towed. Any suggestions will be appreciated.
coolbreeze48 is offline   Reply With Quote
Old 07-15-2013, 11:38 AM   #35
njkode
Los Angeles
2001 Explorer Sport
Vehicle Specs
Quoted: 2 Post(s)
Quote:
From everything I ever read there is no way to bypass the PATS system. Do you have an extra key? When my gf's explore had this problem it ended up being the Key. Of course she only had one. If she would try repeatedly (sometimes it would take up to 30 min) she could get it to start. Once it finally failed that was it she had to have it towed to the dealer and have new keys made.
njkode is offline   Reply With Quote
Old 07-15-2013, 07:07 PM   #36
Dave 1955
Brockport,NY.
2001 Explorer
Vehicle Specs
Quoted: 56 Post(s)
I have maybe a dumb question but I want to know.
If I have a good key and put that up under the dash could I then use just a regular cut key to start it?
Will the transponder in the good key work without actually being in the ign?
Dave 1955 is offline   Reply With Quote
Old 07-16-2013, 12:25 AM   #37
jr_96
Colorado
1997 ford explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Originally Posted by Cobraguy View Post
Every car I've tried to start with a PATS problem won't crank over. Nothing happens but a rapidly flashing theft light. If yours cranks over, I'm thinking something else is wrong.
I have a 97 explorer and i dont have a pats at all and all of a sudden the system wont arm. when i lock the truck usually the theft light for the 95-97 explorers would illuminate and then flashing showing the alarm is armed. now that light doesnt turn on let alone flash. when i lock the truck it doesnt engage the alarm.also i had replaced the RAP module from a 2000 explorer and the keyless entry part works great and it used to engage the alarm till yesterday i locked the truck and the light wasnt on anymore. think you could help me? side note(i cleaned the battery off that morning and charged it at my tire shop and soaked my cables in baking soda and water. for a couple hours)
jr_96 is offline   Reply With Quote
Old 07-20-2013, 03:08 AM   #38
JusTheUsual
Central NY
JusTheUsual's Avatar
1999 Ford Explorer Sport
Vehicle Specs
Quoted: 65 Post(s)
bumped for certain guy looking for a thread like this...
JusTheUsual is offline   Reply With Quote
Old 08-11-2013, 01:09 PM   #39
johnnypunany
2000 Explorer
Vehicle Specs
Quoted: 0 Post(s)
Theft light flashing
Sorry if this was already answered.
But my theft light flashes only when i shut the door after leaving the vehicle. I hit the lock button on my remote and theft light is still flashing. And stays flashing until I return later and turn the car on (with no problem).
johnnypunany is offline   Reply With Quote
Old 11-29-2013, 01:59 PM   #40
dryson
1996 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Here is the issue that I am having.
This morning my Ford Explorer Sport ran fine. I went to auto parts store and purchased some MAF spray and sprayed it into the Mass Air Flow sensor.
I also purchased some Sea Foam to clean any carbon deposits up on the inside of the engine as I have been having idle issues the truck shutting off or dropping to a low RPM when the accelerator is released.
After getting home I added the Sea Foam to the engine via the hose that connects to the canister looking device that is directly behind the brake fluid resevoir.
The Sea Foam performed just like it should and smoke appeared. Shortly thereafter the truck simply shut off and would not restart.
I am assuming that the issue is the Theft Module as the battery is less than two weeks old and the battery charge indicator indicates the battery is low even though I placed a portable charger on the battery for around an hour.
When I try to start the vehicle the engine does not turn over and the truck acts like the battery is completely dead where a loud click comes from the left side of truck.
Also when I try to start the truck several times the power locks will lock and then unlock automatically.
I have already tried the negative battery terminal trick but that has not seemed to fix the problem.
Also when I turn the key to the ON position I can hear the Fuel Pump turn on.
dryson is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Copyright 2016 - 1996 Rick Horwitz Photography Explorer Forum is celebrating it's 20th birthday!!
Ford Motor Company is not involved in the management of this site in any way.
