#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Removing hydraulic clutch line quick disconnect help?!
Reply
Thread Tools
Old 04-23-2005, 11:30 PM   #1
dsfii93sport
Indy, IN
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Now I know I've seen a couple post about getting this off, but my goodness this is not no "quick" disconnect?! I have pushed the lil white ring into its housing tuggin and all trying to get this to come off what gives?
So there is a tool somewhere for this application? What does it look like cause someone pointed me to the wrong thing last time I was at the auto store. I ended up buying those quick disconnect plastic things used to remove fuel lines and it just wont fit in this thing at all... Seems I need some slim strong semi circular device?
Help!
dsfii93sport is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-23-2005, 11:35 PM   #2
dsfii93sport
Indy, IN
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I gotta stop answering my own posts :-P
I guess this is the tool and what it looks like? Correct me if I'm wrong.
http://www.drivewerks.com/catalog/Sh...CAT567_pg3.htm
Dang, that looks so simple!
Old 04-23-2005, 11:39 PM   #3
dsfii93sport
Indy, IN
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I still can't see how this thingy is going to push the white ring up any higher? Anyone know if that ring is suppose to be further than flush or do I have another problem?
Old 04-24-2005, 08:53 AM   #4
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 184 Post(s)
I just used a small flat screwdriver to tap the white ring in. At first it wouldn't come apart, but the trick turned out to be to push the ring in further than you think is necessary.
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is online now   Reply With Quote
Old 04-24-2005, 09:40 AM   #5
mechanix
Got beer?!?!?!
Springport, Michigan
mechanix's Avatar
91 xlt & 93 xlt
Vehicle Specs
Quoted: 0 Post(s)
The small screw driver works. You will want to push the lil white ring in untill you can't see it any more. When you do that give it a twisting and pulling motion all the same time. Be careful, cause when she goes you will smack the hell out of your hand. Might need to use the screw driver all around the little clip. Also you could try using compressed air to blow any kind of dirt or junk from inside the quick disconnect area.
Hope this helps.
__________________
ASE certified mechanic.
91 XLT on 36's.
2005 F150 XLT -Tow rig.
mechanix is offline   Reply With Quote
Old 04-24-2005, 06:51 PM   #6
dsfii93sport
Indy, IN
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
After some mauling and hitting and twisting I am still in the same damn boat... haha... I do have one question though if anyone knows... ?? Where does this come apart at?
There is a copper peice that the hydrolic line is shrinked to, then this copper peice goes into a brass peice. In between this brass and copper is the white ring which i have pushed all the way in. Now... Does this copper peice suppose to pull out of the brass w/ white ring,, OR... does the whole brass peice come apart somewhere up higher inside the bellhousing thats hard for me to see? Guess I feel it might help knowing where it is going to seperate at.
Old 04-25-2005, 02:47 PM   #7
dsfii93sport
Indy, IN
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well, is there any stipulation to just removing the line from where it connects on the other end? besides having to bleed the clutch system when all said and done....
Is the other end just a nut I loosen and remove the line?
Old 04-25-2005, 03:26 PM   #8
mechanix
Got beer?!?!?!
mechanix's Avatar
91 xlt & 93 xlt
Vehicle Specs
Quoted: 0 Post(s)
Where the white ring is, that is where it comes apart. You do have the white ring pushed in at the top of the line too?? The white clip is like a fuel line, if you don't have it in all the way you wont get it apart. Another thing I have done is to cut the hard plastic line and use a compression union to place it back together. This seems to work well. If you follow this route make sure you cut it in a straight part of the line. Doing it this way is a pita usually cause it takes forever to get all the air out.
On the other end of the line it is held into the master cly with a roll pin and the line just slides in the end. This was could be a pita also, cause you will have to pull 2 foot of hard plastic line out with the trans and becareful not to damage it on the way out and like wise when putting it back it.
Best of luck!!!!
__________________
91 XLT on 36's.
Old 04-25-2005, 03:32 PM   #9
dsfii93sport
Indy, IN
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have hammered a lil screw driver all around this thing so that the white ring is about a tenth or 2 of an inch inside the brass all the way around. Still no budging at all and doesnt feel the white ring will go up anymore... Should I be able to turn the copper part while holding the brass outer part still? Or is there some key in there to keep it from rotating?
Old 04-25-2005, 07:13 PM   #10
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 184 Post(s)
Here's a pic of the slave. The line clicks into the end of the copper part. Hope this helps some.
I would try pushing the white ring in further. You're pushing it in straight, right? Tapping at the top, bottom, left and right, so it goes in evenly?
__________________
Bill Collins
93 Ranger XLT 4X4
Old 04-27-2005, 11:48 AM   #11
dsfii93sport
Indy, IN
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well thank you for the pic, it did help.. but I still had no luck getting it off and I'm done fishing w/ it.
Someone said cut the line and barb splice it later,, has anyone done this? Will a standard barb like for the fuel lines hold this okay? I have no clue what the pressure is in this line when the clutch is pressed? Anyone have any idea?
I read somewhere that hydraulic clutches can reach up to 500 psi oil pressure and I dunno if this specific design is like that and if it is,, will a simple barb connection withstand this?
Old 04-27-2005, 01:05 PM   #12
dsfii93sport
Indy, IN
93 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
BINGO!!!
I got it finally after a refreshing retry this morning! haha.. Let me give the next person a hint for doing this easier! After you push the little white ring up in there as far as it will go, simply use on of those small prybar used on removing baseboards from lowes ( mine is about 15" long and angled about 45' on 1 side and about 180' on the other ) Well I placed the 45' side up against the copper right in the groove thats near where the hose connects, then lay the pry bar against the tranny, push the bar so that it wont slip off the groove and hit it w/ a hammer which forces the quick disconnect to pop right out without tugging w/ your hand and worrying about blowing up your precious blood vessels! haha..
Thanks again everyone for all the help..
Old 11-02-2010, 01:02 PM   #13
ckurtz
newyork
1999 ford ranger 4.0 xlt
Vehicle Specs
Quoted: 0 Post(s)
hey
should that brass thingy move when it is connected to the tranny?
ckurtz is offline   Reply With Quote
Old 11-02-2010, 02:41 PM   #14
Iron Weasel
Belen, New Mexico
1994 XLT 4x4
Vehicle Specs
Quoted: 2 Post(s)
It can move a little bit, but if it's flopping all over the place then it might be a problem.
Iron Weasel is offline   Reply With Quote
Old 11-03-2010, 08:33 PM   #15
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 184 Post(s)
Quote:
Define "move".
__________________
Bill Collins
93 Ranger XLT 4X4
Old 01-20-2013, 07:12 PM   #16
enzoreno
tucson,arizona
1997 ford ranger xlt
Vehicle Specs
Quoted: 0 Post(s)
Sweet!
Now I'll try to disengage that damn line...
enzoreno is offline   Reply With Quote
Old 01-20-2013, 10:36 PM   #17
enzoreno
tucson,arizona
Vehicle Specs
Quoted: 0 Post(s)
oh,yes!
it worked with the screw driver,a thiny one,and pushing the white plastic deep,and then pull the line out.
piece of cake...
thanks.
Old 07-27-2013, 11:12 AM   #18
PatrickWardak
1994 Mazda B4000 4x4 V6
Vehicle Specs
Quoted: 0 Post(s)
Is this technique the same for a Mazda B4000?
PatrickWardak is offline   Reply With Quote
Old 07-27-2013, 12:59 PM   #19
Carguy3J
North East New Jersey
'99 4dr. XLT SOHC A4WD
Vehicle Specs
Quoted: 118 Post(s)
Quote:
Yes. A Mazda B4000 is a Ranger, with only some cosmetic/trim differences. Mechanically, they are the same.
__________________
1999 Explorer XLT 4dr, 4.0L-SOHC, 5R55E Auto, A4WD
K&N FIPK Cold Air--XCAL3 w/ custom tunes from Henson Performance
On The Way: Gibson Cat-Back,U/D pulley,Professional Products Polished 70mm Throttle Body **Planned soon:80mm MAFS,Removal of the Cats,Electric Fan
Best Time 15.87 e/t @ 86.6MPH in the 1/4
Carguy3J is offline   Reply With Quote
Old 07-31-2013, 03:39 PM   #20
PatrickWardak
Vehicle Specs
Quoted: 0 Post(s)
Yeah that's what I thought until I had to get a wheel bearing adjusting nut. But thanks for the reply, I'm hoping they're the same.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
