#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
HOW TO: Remove Rear Hatch Panel
Reply
Thread Tools
Old 05-22-2005, 07:16 PM   #1
TTG
Florida Gulf Coast University, Fort Myers, Florida
'95 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
This is a guide on how I removed my rear hatch panel so everyone else doesn't have to search through countless threads with vague instructions on how to do it.
Step 1: Remove the plastic pins around the top pf the hatch. These should be the same color as your interior. To remove them you can either buy the actual tool to do it at any local car parts store, or just take a set of screwdrivers and pry.
Step 2: Remove 2 screws holding the pull strap in. It's that little thing that hangs off the panel when you open the hatch up. The 2 screws are directly under the strap's base.
Step 3: Pop out the plastic piece from the lock indicator. It just pops out with a little prying from your screwdriver.
Step 4: Remove a screw next to the lock indicator. It should be underneath where the plastic piece we just pried out was.
Step 5: Yank the panel off. To do this, pull it towards the front of the truck, and it shoulc just pop out. You may get all the front clips and need to force the rear clips forward by hand.
To replace it, just do the steps in reverse.
Taking your rear panel off is necessary if your rear hatch knob is sticky and doesn't turn well(my problem). It's also helpful if you wanted to add speakers back there or soemthing else.
TTG is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-23-2005, 03:43 AM   #2
JasonF
2004 XLT 4x4 4.0
Vehicle Specs
Quoted: 0 Post(s)
Once you got the hatch off what did you do to fix the sticky door handle? Mine has the same problem.
Jason
JasonF is offline   Reply With Quote
Old 05-23-2005, 11:28 PM   #3
TTG
'95 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I sprayed PB Blaster on the little turny part. Mine was all rusty and so it was kinda a no brainer that was the problem. I was planning on putting some teflon grease in there, but its a cylinder piece with all the stuff inside it, so you can't really get much grease in to help. I suppose if it's really bad you could always replace that piece, not sure how you'd go about that or how much that'd run though.
What does this all mean? WD-40 and PB Blaster can solve most problems.
__________________
My Cardomain
Old 11-09-2011, 03:22 PM   #4
wguage52
Belle Harbor NY
2000 Ford explorer
Vehicle Specs
Quoted: 0 Post(s)
Rear Hatch Actuator
With the help of a member I got the rear hatch open and with addtional threads removed the panel. However , I cannot get the actuator out. I Have twisted and manipulated but the hook will not come out of the latch mechanism. I noticed there is a yellow piece of plastic that the hook goes through but I cannot remove that either. Anyone got a clue ?
Thanks to the members for getting me this far.
Bill
wguage52 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
