ftexplorer
- September 20, 2005
- Caldwell, NJ
- 00 XLT
Hello All,
I've received some good information for this forum and decided to contribute. Forums like this are so helpful when you need to have information. I have intensely researched changing and flushing my transmission system. All the answers are not on 1 post. I'm going to hopefully get it all in one post for stock Explorer owners. I have a 2000 XLT 4x4 4.0L SOHC. These instructions can be modified towards your year...hopefully.
Here is what you'll need.
1. Buy yourself some ramps to drive up on. The $30 or so dollars you will spend will save you a lot of headaches.
2. You'll need a 13 millimeter nut for the pan. The ATF filter is also a metric size. I used a 3/8" ratchet for the pan and a 1/4" ratchet for the filter.
3. You'll need some vaseline. I'll explain later.
4. You'll need a decent sized catch pan. I used a 15 quart pan, and it held all fluids.
5. Many rags
6. A rubber or vinyl hose 5/16" in diameter for the opening
7. 15 quarts of Mercon V fluid. You can return the unused
8. A good filter. Forget the cheap **** one at Autozone. It's made in Taiwan. I bought mine at PepBoys, and it was a Purolator. Any American made one should be good.
Here is the process to change the filter and flush the system. It's for the newbie to the intermediate.
1. Put aluminum foil around the catalytic convert to protect it from fluid drain. Also put aluminum foil around the piece before the catalitic right under the pan.
2. Once under the truck, you'll need a flat head screwdriver to pry off the heat shield from the pan. The clip furthest away from the engine (only 2 clips) comes off easily. The second clip will not come off all the way. Don't bother with it as it will be out of your way when then pan comes off.
3. Start unscrewing the screws little by little. Each screw should be undone about the same distance. The fluid will start to leak once the screw become loose. Then drop the front screw more. The fluid will leak more from the front when you unscrew those further. Then unscrew all the screws but the ones on the passenger side. The pan should hang towards the driver side. The fluid will then poor out of that side and the back. There is no way to keep this clean. The way I described wasn't too bad. I had a big cardboard box (flattened of course) under me to portect the garage floor and to absorb the fluid. At this point, unscrew the remaing screws. The pan still has fluid in it. It will come out towards the driver side. You shouldn't have to disconnect anything else to get it off.
4. My gasket was stuck to the trans and not the pan. It came off easily. I cleaned the screws and the pan with denatured alcohol. There will be a magent in the pan. Clean that well. I also cleaned the rim of the trans where the gasket goes with a rag soaked in the alcohol. Don't use regular isopropyl alcohol. You can find denatured alcohol at Home Depot or any hardware store that has solvents. Use an air bloer to get loose dirt out and to dry the pan. I used the one in the can.
5. The filter comes off next. It should pull down easily. I reused the filter screw. The new filter came with the o-rings. I oiled them with new fluid before installing them. There are only 2 of them.
6. Once the filter is replaced and the pan cleaned up, you'll need some vaseline. I used a little in the pan grooves on all 4 sides. I only used it in one of the grooves in the middle per side. It kept the gasket somewhat in place when I went to put it on. The pan should go on without any problems. You'll have to line up the gasket with the holes so the screws can go in. The heat shield should naturally be up and out of your way before re-attaching.
7. Screw the screws in by hand in a criss cross pattern. This means an X like pattern. I started with the ouside corners and worked in. They say to use a torque wrench. I don't think you need one. Tighen them by hand as much as you can. The use the wrench to get the play out and tighten them nice and snug. Tight but not too tight. Go around a couple of time to make sure because there may be some play in the screws.
8. Add 4 quarts to the pan through the pipe the dipstick goes into.
9. The 2000 has an extra trans fluid cooler. Older models may not. You'll want to unplug the rubber hose from the radiator or trans cooler that feeds the in line of the transmission. This is the top line coming out of the trans. If you have the extra cooler like I do, it is the left line when looking at your vehicle from underneath with your head facing towards the engine. You'll unscrew the fastner. I did it by going through the bumper. Then you'll drop it. Dirty fluid will come out. You can then attach your hose to the nipple on the trans cooler or radiator. I used a clear tube to see the color of the fluid, and it was about 1.5 feet long. These can be purchased at Home Depot as well. For the hose that just came off, get a big enough screw to fit the diameter (don't thread it) and re-tighten the fastner. I didn't the first time and fluid also came out of that. It wasn' so bad in the sense that the crap fluid came out. I noticed it quickly though.
10. For the next step, you'll need a partner. Turn the car on. I have read elsewher to put it in neutral, but I found it worked better in park. It will flow after a couple of seconds. Stop the engine if too many bubbles come out, wait a few seconds, and restart it. Have a container that measures out a quart. I used an old water bottle. A quart is 32 oz. Have the partner turn on the car and drain out 1 quart. Then shut off the car. You'll need a catch pan underneath to get the extra drainage from the tube. Add a quart to the pan. Repeat this process until the fluid starts coming out cherry red. It took me about a total of 11 quarts.
11. Once cherry red, disconnect the hose you attached and re-attach the trans cooler line.
12. Once it's all reattached, start the car and check for leaks. If no leaks, rev the engine to about 2500 RPM for a few seconds. Then proceed to move between the gears with the brakes on. The fluid should be flowing well.
13. Take the car out for a drive and get it to normal operating temperatures. When you come back, you might not have the right amount of fluid. With the car running, take out the dipstick, clean it, and reinsert it for a reading. If you are not in the crosshatches, add some more fluid and repeat the process with the dipstick. The dipstick on the first pull will catch fluid in the tube, and you will not get an accurate reading. Don't overadd. You will be safer adding small amounts. It's time consuming but better than having more fluid. The fluid needs to be measured when the car is hot. Once you have the right amount, you are all done.
I hope this post helps everyone. I probably won't respond to post as I am not on the list to receive notifications. There was a lot of research that went into this. The whole job should take about 4 to 6 hours. Good luck if you try this. It's not that hard, and the car runs so much better with clean fluid.
5. Many rags
