JChrisMarion
- July 18, 2006
- Lakeland,FL
- 1997 Explorer 5.0 AWD
Finally after viewing many projects by other members, I took alot of things into consideration. I did not want to cut any trim panels, wanted it to look stock, all panels fit perfectly and utilize as much space as I could. I started off wanting to use a Boston Acoustics G2 10" subwoofer, problem was I needed 6 3/8" mounting depth plus a 1/2" space for VC vent. So that speaker and idea was thrown. After consideration for fitting a 10" with no alterations to the trim, I had to choose a 8" sub. Now I could have fit a 10", I just would have had to trim around the rear factory box cover with grill. Where it has those pain in the butt snaps that hold it in place. If I would have done that a 10" would fit perfect, so you could do it if you wanted. The box is .4 cuft of airspace. A good hard hitting 8" this is perfect for. I chose a MA Audio MA800XL since it is a 4ohm DVC with 400watts RMS/800 Max, and 4.8in mounting depth. 200oz magnet,dual spider and more. They sound good and thats some performance for an 8!
Cut it, built it, sealed it, beyond secured it, covered it, mounted it and VOILA. It is done and looks perfect to me. Now to figure out where to mount the amp?!
Tell me what you think!!
http://s20.photobucket.com/albums/b207/JChrisMarion/Explorer/
