manaen
- February 27, 2007
- Clear Spring, MD
- 2011 Xterra Pro-4X
OK, I have a very strange problem here, my oil is always showing high. This morning I changed it and checked it, it was fine. Then I drove about 100 miles and now it is showing about 1qt high with a strong smell of gas. So I figured no problem it must be the fuel regulator, well I vacume tested the diaphram which hold vacume and seems to be fine. There are no codes, the engine runs great, the only problem is the over full oil and smell of gas in the oil. Were other than the FPR can the fuel be coming from to make my oil so high. I will be going out and checking the EVAP after typing this but I'm not really sure what to check with it. Hopefully someone has some good ideas here. I am at a loss, since there are no code and the engine runs great, that means the fuel must be getting into the crankcase directly (IE not passing through the intake) otherwise I would think the engine would either burn it up, and/or run very rich which it is not. I am a bit conserned about running this thing with fuel in the oil, and I need to us it
Oh btw this is a 2001 Mounty 4.0 SOHC 4x4
TIA
TIA
