RubySlow
- March 18, 2007
- Pacifica Ca to be S'Pacific
- BAYDESTRIAN
Okay so if your interested in Upgrading your throttle body maybe a 70mm or 75mm from a 87-93 you will need this wiring diagram. You can use your stock tps but Only one of the bolts on the TPS will line up on the Mustang T-Body.
So I recommend wiring the mustang TPS to your explorer/mounty harness....
Here is my write up on a mustang T-body
http://www.explorerforum.com/forums/showthread.php?t=193895
Here is the Diagram...
Explorer/Mounty tps wiring is
BRN/WHT - is for VOLT REF.
GRY/WHT - is for TP SENSOR INPUT
GRY/RED - is for SIG RETURN
ok and the Mustang 87-93 Tps wiring is
ORG/WHT - is for VOLT REF.
DRK GRN/LT GREEN - is for TP SENSOR INPUT
BLK/WHT - is for SIG RETURN
