Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Runs and Events > Offroad 4x4 Runs Planning and Discussion
Notices
Offroad 4x4 Runs Planning and Discussion Take your Explorer offroad. Drop your 4x4 into low range, or air out your pre-runner. This is the forum for your offroad explorations.
Offroad Checklist
Reply
Thread Tools
Old 11-18-2007, 12:23 PM   #1
mcpherson
Cumming, GA
mcpherson's Avatar
'98 XLT, '88 YJ
Vehicle Specs
(Original Poster)
Arrow Offroad Checklist
Well, I'm not so sure if this is exactly a "How to's" checklist, but I do believe to be very important for every off road driver to take into consideration before taking a trip to the trails.
Offroaders.com - I have referenced most of this information from another site and will give them credit. I made some changes only to a few items.
Explorer4x4.com - In addition, i have updated this list with information referenced from Gerald Jarrett - Trail Equipment Required Items
This is also posted on our club site.
Offroad Checklist
Offroaders Guide to Gearing up for Offroad
  • The Basic List
  • Safety and Survival
  • Beyond the Basic Offroad Checklist
  • Vehicle Recovery Items
  • Tools Checklist
  • Versatile Items
  • For the Vehicle
  • For the Serious Offroader
  • Basic Camping / Extended Stay List
  • 25 Tips to do before going Offroad
Basic Tips
  • Always travel in groups of 2 or more vehicles
  • Always alert someone back home where you are going and when you expect to return
  • Take at least a basic supply of tools and gear
Pre-departure Maintenance Checklist
  • Check engine oil
  • Check transmission oil
  • Check brake fluid
  • Check radiator coolant for leaks, fluid levels, clean fins, thermostat and radiator cap
  • Check battery for damaged or corroded wiring, clean terminals
  • Check windshield wipers for wear and fluid level
  • Check fan belts for cracks
  • Check hoses for cracks and bulges
  • Check air cleaner
  • Check seat belts
  • Check tire air pressure (air up to recommended pressure for highway driving, air down at trail head, air up prior to trip home)
  • Check tires tread wear or damage (including your full-size spare), look for cuts and missing chunks
  • Check and tighten lug bolts
  • Tighten drive shaft u-bolts
  • Check for body/frame cracks
  • Check brake pads & shoes (adequate braking pad material, in good condition and without contamination)
  • Check for loose bolts or nuts throughout vehicle (loose nuts will lead to shearing the studs off)
  • Grease all fittings (u-joints, steering)
  • Check gear oils: transfer case/differentials, replace if necessary
  • Check Winch for proper operation, check winch cable for kinks, frays or damage, straighten winch cable if necessary
  • Check headlights, brake lights, auxiliary lights; make sure they're aimed properly
  • Check suspension including springs, shocks, alignment, wheel bearings and steering linkage
The Basic, Minimal Offroad Checklist
The minimal list is the basics that you should always carry in your vehicle when offroad. These items are good to have in the vehicle at all times.
  • First Aid Kit (See Safety and Survival below)
  • Basic Personal Essentials (water, food)
  • Spare Tire, Full Size
  • Jack and tire iron to change your tire
  • Tow strap
  • Tree saver
  • Come-alongs
  • Basic Tool Kit
  • Spare Key for vehicle kept on your person
Safety and Survival
  • The First Aid Kit
    • First aid kits come in many shapes and sizes. You can buy them, or you can make your own kit. Whether you buy a first aid kit or put one together, make sure it has all the items you may need. Include any personal items, such as medications. Keep ID card (and/or copies), emergency number contact info and medication allergy in your purse, in your vehicle glove box, and in your first aid kit.
Here are suggestions for the contents of a first aid kit:
  • Activated Charcoal (use only if instructed by Poison Control Center)
  • Adhesive Tape
  • Antiseptic Ointment
  • Alcohol swabs, individually wrapped
  • Band-Aids (assorted sizes)
  • Blanket
  • Cold Pack
  • Disposable Gloves
  • Gauze Pads and Roller Gauze (assorted sizes)
  • Hand Cleaner
  • Plastic Bags
  • Scissors and Tweezers
  • Small Flashlight and Extra Batteries
  • Syrup of Ipecac (use only if instructed by Poison Control Center)
  • Triangular Bandage
  • Burnaid gel
  • Snake Bite kit
  • Disposable emergency blanket
  • Instant Cold pack
  • Instant Hot pack
  • Medications:
    IMPORTANT: LOOK AT THE EXPIRATION DATE ON ALL MEDICATION PACKAGES! DO NOT USE ANY MEDICATIONS AFTER THEY EXPIRE. ALSO TEMPERATURE CHANGES AND HUMIDITY CAN CAUSE MEDICATION TO BECOME INEFFECTICE OR DANGEROUS. Anti-diarrhea medication, Tylenol ( fever reducer), Ibuprofen (Nuprin, Motrin, Advil) inflammation reduction, sprains bruises, etc, Benadryl for mild allergic reactions, Epinephrine in the form of an Epi Pen to treat more serious allergic reactions that might otherwise be fatal.
Safety Items
  • Safety Glasses
  • Leather Gloves
  • Fire Extinguisher - Should be mounted in the vehicle in an easily accessible location.
  • Flares
  • Tarp
  • Flashlights
  • Matches / lighter
  • Water - At least 1 Gallon per person, per day if not more. Drier, hotter climates require at least 2 Gallons, per day if not more. Remember: Alcohol doesn't hydrate. In fact alcoholic beverages dehydrate since it take more water to metabolize alcohol than the beverage contains. Plus it may cause you to require the above mentioned First Aid Kit.
  • Food - Bring food for twice the amount of time you are planning on being gone. Should you be delayed and have to spend a night out on the trail, you wont have to worry about going hungry. Good ideas for trail food: trail mix, snacks, beef jerky, fruits, dry/canned food, etc.
  • Extra Cloths - Nobody likes to sit in wet cloths or an extended period of time.
  • Personal items - This includes toilet paper, anti- microbial hand cleaner, etc
  • Sun block
  • Rain Jacket
  • Communication devices - Cell Phone, CB Radio, Amature (Ham) Radio (license required to operate), GMRS/FRS radios
  • Power inverter if necessary (e.g. Cell phone recharger, battery recharger for communication devices and camera)
  • Trash bags - Keep your trails clean
  • Maps, information about the area
  • Compass or GPS
  • Water purification tablets
Survival - Seasonal Specific
  • Winter
    • Extra clothing
    • Warm outer layers (jacket, wind breaker)
    • Head gear (warm hat, hooded jacket)
    • Emergency blanket (compact survival type)
  • Summer
    • Sun Block
    • Insect repellant
    • Sunglasses
  • Hilift Jack
  • Tow straps - 2 or more, 2 inch width or wider, 20 foot or longer
  • Towpoints front and rear, frame mounted
  • Tree saver
  • Come-along (one or more)
  • D-rings, Shackles
  • Shovel (standard or military foldup)
  • Axe (at least hand axe or hatchet)
  • Chainsaw and bar oil, 2 cycle engine oil, spare chain (can be handy in recover situations, as well as for trail clearing on wooded trails)
  • Winch Kit: tree strap, hi-lift jack, snatch block, pickle fork, shackle, gloves
  • Pullpal
  • Snow tire chains (if tires don't cut it)
Basic Tools
  • Complete Socket Set with SAE (standard) and Metric with 3/8" and 1/2" drives. Deep and standard sockets.
  • Crescent, open end combination box wrenches SAE (standard) and Metric
  • Allen Wrenches
  • Torx sockets (especially if you own a Jeep)
  • Standard & Phillips screwdrivers, large, medium, small
Versatile Tools
  • Large Hammer (a.k.a. the "BFH")
  • Pliers (various sizes)
  • Needle Nose Pliers
  • Vice Grips, various sizes
  • Large channel-lock Pliers
  • Pipe wrenches - having 2 medium of these can be useful for tie-rods.
  • Pocket/utility knife or razor blades
  • Crescent wrenches (medium & large)
  • Hacksaw with spare blade
  • A BIG pry bar (or crowbar) or length of strong metal pipe, inside diameter of pipe large enough to slip over a wrench or socket drive for extra leverage.
  • Magnet
Specialty Tools
  • Snap ring pliers
  • Air Pressure Gauge
  • Portable air pump
  • Standard Bottle Jack with 12" square wooden platform for use in soft ground
  • 12 volt and battery powered portable tools: Impact wrench, sawzall, drill, spotlight
  • Jumper cables
Additional Versatile Items
  • Duct Tape
  • Bailing wire
  • Wood blocks - Useful as chock blocks, jacking platforms, ramps, suspension supports (for broken torsion bars)
  • Hose clamps
  • Bungee cords, several in multiple sizes - good for securing gear, temporary repairs, etc.
  • Small ratchet straps
  • Rope lengths
  • Super glue/epoxy
  • Tank sealant putty
  • Tie wraps
  • Rags
  • Work Gloves, leather
For the Vehicle
Fluids
  • Engine Oil
  • Brake Fluid
  • Power steering fluid
  • Automatic transmission fluid
  • Coolant or Water
  • Bearing Grease
  • WD-40
  • JB Weld
  • Starter Fluid
  • Extra gas
  • Funnel, siphon hose
Spare Parts / Repair Items
  • Lug Wrench
  • Extra Fan / serpentine belts
  • Hoses, fuel line, brake lines, coolant hoses, hydraulic hoses or plugs (if using a ram assist or full hydro)
  • Spare Fuel filter (if not using a cleanable one)
  • Spare Hi-steer studs (if applicable)
  • Spare Tire
  • Fix-A-Flat and/or Tire Plug kit, plugs
  • Extra Lug nuts, tire star wrench or lug key with key socket
  • Cotter pins / keys - various sizes
  • Valve stems, Valve stem remover
  • Nuts & bolts assorted standard and metric sizes
  • Spare Leaf spring center bolts
  • RTV or Hylomar HPF - form-a-gasket
  • Radiator stop leak - silver flakes in tube
  • Spare Hub (and hub fuses if applicable).
  • Electric fuel pump
  • Coil / electronic ignition
  • Spare Universal Joints (U-joints for drive shaft & axles)
  • Spare Drive Shaft (rear and front)
  • Extra spark plug wire (size of longest wire)
  • Spare points
Electronics Repair Kit
  • Volt ohms meter (multimeter)
  • Wire cutters / wire crips / wire strippers (multi-tool)
  • Spare fuses of all sizes and types used in your vehicle
  • Electrical tape
  • Spare wire - lengths of various gauges
  • Spare switches
  • Spare relay if you use relays
  • Spare vehicle sensors - TPS, MAP, etc.
  • Crip on ends (male and female, various gauges)
  • Small pocket sized needle point blow torch (handy for soldering wire)
  • Flux core solder for repairs
  • Wiring Diagram of your vehicle
Expanded List
  • Winch and Winch Accessories
  • Onboard Welder, welding supplies, welding gear and misc. metal pieces (for making repairs especially if carrying an on-board welder)
  • Onboard air compressor such as ARB or QuickAir
  • Externally mounted Jerry Can for fuel
  • Spare axles (rear left / right, front left / right)
  • Spare tie rod assemblies (tie rod, drag link, ball joints, ball joint nuts and cotter pins)
  • Spare Idler Arm
  • Parts that have broken twice before (if you can't carry it, you should have upgraded it)
Camping List for Extended Stay or Remote Excursions
  • Camera and/or Camcorder
  • Compass and/or GPS
  • Hiking boots or comfortable walking shoes (if you are not already wearing them)
  • Duct Tape
  • Flashlight
  • Propane Lanterns
  • Mosquito repellant
  • Lighter, matches
  • Firewood
  • A knife of some sort
  • Toilet paper
  • Towel
  • Water purification pills
  • Backpack/sacks
  • Cooking Pans for breakfast
  • Paper plates
  • Paper towels
  • Folding camping chairs
  • Sleeping bag
  • Sleeping pad or air mattress
  • Stove or grill and fuel
  • Tarps, lots of tarps
  • Tent(s)
  • Bathing suit
  • Flip flops or swimming shoes (no bare feet while swimming)
  • Funky fishing hat
  • Hiking boots
  • Rain jacket
  • Sunglasses
  • Sunblock
  • Soap - Antibacterial
  • Waterless hand scrub and/or Wet Wipes
  • Binoculars
  • Bottle opener
  • Cooler cup
  • Jacket
  • Pocket knife
  • Snacks
  • Trash bag
  • Water
  • Extra keys
  • Compass
  • Sunscreen
  • Hat
  • Sunglasses and/or goggles
  • Ice and ice chest or cooler with beverages and food (cooler with latching top and handles to use as strap point)
  • Camera, case, film and batteries
  • Maps: Sidekick Off Road Maps, state, county, Forestry, BLM Desert Access Guide, etc.
__________________
Nick, KJ4QIZ
'98 Explorer XLT - mcpherson's Registry
'88 Jeep Wrangler - mcpherson's Build Thread
"If anything can go wrong, it will" - Murphy's Law
mcpherson is offline   Reply With Quote
Old 11-18-2007, 01:03 PM   #2
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Nice post! Thanks for the comprehensive list. I moved it from the Tech Corner, its a better fit here.
MountaineerGreen is offline   Reply With Quote
Old 11-18-2007, 01:18 PM   #3
mcpherson
Cumming, GA
mcpherson's Avatar
'98 XLT, '88 YJ
Vehicle Specs
(Original Poster)
Quote:
Thanks!
__________________
Nick, KJ4QIZ
Old 11-18-2007, 02:19 PM   #4
Donner
Natomas/Irvine
01 Sp 03 XLT 4x4s, Scion
Vehicle Specs
If this is a no post zone, please forgive me...
This is THE most comprehensive and informative set of guidelines for O/R preparation; and very genuine. It seems like in addition to being in this location (where mostly offroaders come to) it should be posted right up front where green people can see it, in other words it should be a must read, readily available for EVERYONE that comes to this site. It should literally be found in every forum...
The people at this site have a way of converting the average person with a daily driver into someone with a vehicle they feel proud of... Once you come to this site, you don't know if you'll be offroading someday, building a street machine or just learning about vehicles.
What you have presented is a SURVIVAL guide, many of the items are things we should have ready just in case of anything. McPherson, this came from your heart... Just to present it shows you truly love what you do and respect the people that share your time and interest.... how it was compiled is not as important as WHY it was compiled... Amen to you.
__________________
http://www.explorerforum.com/forums/...d.php?t=240001 For Sale stuff
Donner is offline   Reply With Quote
Old 11-18-2007, 04:25 PM   #5
Charlie
Wisconsin
1995 F-150
Vehicle Specs
Great list, this should be a sticky!
__________________
Link to lift and max tire size info
1996 Sport
2000 XLT
1995 F-150
1987 F-150 XLT "The General"
Charlie is offline   Reply With Quote
Old 11-21-2007, 07:17 PM   #6
GJarrett
Moderator Emeritus
Chief GPS'um and Still Lost Native Texan
GJarrett's Avatar
'99 EB 4x4
Vehicle Specs
Yep I'll sticky this. It is a very good list and amazingly close to one we did put together on this site several years ago when I compiled information from many of the experienced offroaders on this site and then wrote an article on the subject. It's still here but has gotten buried under years of postings on the forums here.
If you're interested on the what the "oldtimers" here suggested for trail equipment many years ago and want to compare that to this list, you can find the old one here at http://www.explorer4x4.com/trail_equip.html
That list was "required reading" for Moab participants for many years to help newcomers to Moab properly prepare for the run.
Enjoy!
.... and see ya on the trails
__________________
Ol' Krusty
"Nerves of Steel; Brain of Chipmunk"
Gerald's Truck
The best things in life........ aren't things.
God's aim looks like He's missing the mark because we're too nearsighted to see what He is aiming at.
GJarrett is offline   Reply With Quote
Old 11-21-2007, 10:57 PM   #7
Brian1
Albuquerque, NM
Brian1's Avatar
1991 XLT
Vehicle Specs
I have a few things to add from my own experiences and what I carry, sorry if I repeat any from above:
First Aide Kit - CHECK the expiration dates on the medications and replace as needed. Often we leave our kits in our vehicles for years and never do this.
Pre-trip check:
Torque your high-steer arms if applicable. Loose nuts will lead to shearing the studs off.
Spare Parts:
Fuel filter (if not using a cleanable one) -Last 2 trips I have been hit by this
Hydraulic hoses or plugs if using a ram assist or full hydro
Hi-steer studs if applicable
Brake lines (was not explicitily stated above)
Misc. metal pieces for making repairs especially if carrying an on-board welder
Hose clamps
small ratchet strap
Brian1 is offline   Reply With Quote
Old 11-22-2007, 01:55 AM   #8
mcpherson
Cumming, GA
mcpherson's Avatar
'98 XLT, '88 YJ
Vehicle Specs
(Original Poster)
Arrow Updated List
Thank you GJarrett for making this a sticky and for referencing your write up trail equipment, i have made a few change using some of your information. Also thank you Brian1, I have also added your recommendations to the list as well.
__________________
Nick, KJ4QIZ
Old 11-22-2007, 11:00 AM   #9
GJarrett
Moderator Emeritus
GJarrett's Avatar
'99 EB 4x4
Vehicle Specs
Quote:
Originally Posted by Brian1 View Post
Spare Parts:
Yep, I forgot that one.... that's come up multiple times on the trail. Be sure you've got a spare one of those.
__________________
Ol' Krusty
Gerald's Truck
Old 01-24-2008, 04:31 PM   #10
little x
SW VA
'91 XL
Vehicle Specs
Under Vehicle Recovery Items, in the winch kit he lists a pickle fork.
What would that be used for?
little x is offline   Reply With Quote
Old 01-24-2008, 06:10 PM   #11
rookieshooter
Martinsburg WV
rookieshooter's Avatar
84 BII "Li'l Samson"
Vehicle Specs
I guess it could have been put in one of the tool listings. I don't know. But it's a good idea to have one. Or are you asking what is a pickle fork? If so, it's used to remove ball joints or to seperate things. It is a slotted fork thing that is also wedge shaped.
__________________
"2012 & 2011Truck Nationals" At Carlisle Extreme 4x4" First Place winner.
"2012 &2011 All Ford Nationals" At Carlisle First place winner Bronco Trail Truck
Featured in 2012 Bronco Driver Mag.
Petersen's 4Wheel mag ROTM. Voted 2008 Bronco II of Year
rookieshooter is offline   Reply With Quote
Old 01-24-2008, 06:45 PM   #12
little x
SW VA
'91 XL
Vehicle Specs
I have a pickle fork. I just couldn't figure out why I'd be using one while winching.
Old 04-28-2008, 11:35 AM   #13
Dannyboy
Other Make & Models Mod
43°48′48″N 91°13′59″W
Dannyboy's Avatar
91 4 do'
Vehicle Specs
I am prepping for Moab and wanted to add my 2 cents to this great list of items. It was very helpful in my planning of the on board “permanent” and “removable” items that will be worked into my new roll-cage & cargo management. I used to pile my gear into big “action packer” tubs that worked well, but it was always a little less than desirable for organization.
One item I looked for but may have overlooked is a few pieces of chain and nuts and bolts that can fasten them together, this can be very helpful (most guys have this in their winching kit)
1) Loop around an axle and bolt it together to reduce droop, makes hi-lifting much safer when a suspension doesn’t travel 10” down before lifting a tire
2) Chain and a come-a-long can be bolted to the frame opposite of each other to secure even an axle that may have a broken coil, coil bucket, shackle, radius arm, track bar, steering, etc.
3) Chain (and tow straps) can be inserted in a 2” receiver for a guaranteed no-exit point for securing or recovery. (don’t use chain, especially bolted together for recovery, however, my removable winch hand been chained to my trailer frame to winch a vehicle up the ramps before)
4) The beauty of chain is that you can use each length with a bolt to secure things (like a broke swing-a-way tire carrier, with a point every inch to tighten or loosen it up.
I’d like to add an “On The Trailer” list, as nearly every Truckhaven Trip I’ve been to has involved a campsite repair to get one of our members either home or back in action the next day. I am fortunate enough to have parted out an old truck, therefore I have a box of items that does nothing but sit on my shelf, I bring it along and usually take it home just as I found it, but Murphy’s law, if it’s going to break it will break out there and my box of parts does nothing sitting in the garage. Personally I’ve had the terminals snap on my fender mounted solenoid twice, my alternator lock up on the trail, I’ve seen water pumps start to leak and be replaced. Some stuff is general maintenance (such as leaking differentials, or radius arm bushings) that should be done before hitting a trail and some of this stuff just fails at the worst possible time due to the fact that a trail truck doesn’t see much regular use so sitting then getting pounced can cause parts to fail without many hour/miles/years of use.
On the trailer-
Magnetic tool tray
Oil catch pan
Floor jack
Welder
Brake line flare tool & bender
Vice or press (trailer mounted or receiver mounts work awesome)
Examples of my “trailer supplies” and why
Spare knuckle, rotors, spindle, bearings lug studs, spindle nuts, caliper(s), (if you have an old one lying around-if a bearing locks up it can weld itself to a spindle leaving you dead in your tracks) I basically have a spare knuckle out assembled including all the clips, washers etc
radiator hoses, water pump, thermostat -
alternator, belt tensioner, fan clutch, (all have locked up on me randomly or mud induced)
battery cables, starter, starter solenoid,
light bulbs, 4x4 buttons, headlight switch,
steering assembly, shock/suspension hardware (old bushings etc),
fuel pump,
u-bolts, shackle (don’t ask)
I love wheeling with the group from this forum, even more reason to pack every Ford part I have, I have seen the craziest things go wrong and get fixed or leave a guy missing a day of fun. Preparation is the key, but every time you upgrade, there is a new weakest link. Bring your old parts because you can help somebody else out.
Dannyboy is offline   Reply With Quote
Old 03-17-2009, 10:22 PM   #14
ncredneck16
concord, nc
1993 explorer sport 4.o
Vehicle Specs
i recently got a explorer in december and im working on lifting it and cant find a good spot for a tow hook or shackle. can someone post a pic of what they did to there so i can get a reference.
ncredneck16 is offline   Reply With Quote
Old 01-07-2010, 08:11 PM   #15
explorerguy89
Marlton, NJ
1999 xls and 2000 xlt
Vehicle Specs
nice list =] all items can come in handy
__________________
"v8powerbaby[04:48pm] : explorerguy i will make love to you for helping me fix that"
99' ex. xls been through hell and back
Quote:
Originally Posted by benji
I LOVE PINK FUZZY HATS!!
Quote:
Originally Posted by Tim Shaw
great.....bought the wrong deodorant. now i smell like watermelon bubblegum.....
explorerguy89 is offline   Reply With Quote
Old 12-31-2010, 09:26 PM   #16
safn1949
Mankato, Minnesota
safn1949's Avatar
M60A1 my first offroader
Vehicle Specs
Quote:
Easy,install a front and rear class 3 trailer hitch.Takes a beating when you bottom out each end and gives a solid place to hook to.
__________________
1994 XLT,4.0,3.73 LS
149,000 miles.
Need a Panasonic Toughbook? I have them,email me for details.
safn1949 is offline   Reply With Quote
Old 06-16-2011, 06:13 PM   #17
YoungMounty
Alabama
'97 Mounty 5.0 V8 AWD
Vehicle Specs
Will a frame mounted brish guard suffice for tow points? I have used it once before to pull someone out of a situation and it seemed to hold up pretty well, I just wanted the opions of y'all more experienced members.
__________________
1997 Mercury Mountaineer, 5.0L V8 AWD
YoungMounty is offline   Reply With Quote
Old 06-17-2011, 09:06 AM   #18
Dannyboy
Dannyboy's Avatar
91 4 do'
Vehicle Specs
I would not use a brush guard, way too flimsy. You could probably find a way to mount tow points on the same bolt holes. I ruined a class 3 round tube hitch by wrapping the strap around it instead of inserting it into the receiver. Pulled it out of wack. Look up gm towhooks on here, you will like it
Old 10-02-2011, 10:18 PM   #19
Gabe96Explorer
DIRTAY NEW JERSAY
96 Explorer 4x4 Sport
Vehicle Specs
This is an amazing batch of information. I am going to copy this for my clubs website.
__________________
Ole Dirty! - 96 4X4 Sport.
Jade - 96 4 Door XLT.
JOIN US @ www.FUBAR4X4.net
You won't find nothin' that he can't fix, with WD40 & a Craftsman Wrench!
Gabe96Explorer is offline   Reply With Quote
Old 05-07-2012, 03:48 PM   #20
explorinitup
virginia beach, virginia
97 explorer 5.0
Vehicle Specs
love this info.
__________________
...im sorry officer the truck..she just wants more....
explorinitup is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
