Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Wipers won't park & only work on Hi
Reply
Thread Tools
Old 12-03-2007, 12:37 PM   #1
vevalachris
Marysville,wa
94 xploder
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
94' xploder and the wipers wont go to park & only works on high. I've done a little diggin and cant really get a feel of what is wrong. Is it the mult switch on the column? Is it the wiper motor? Is it too old to have a GEM module? Is it a relay? Help me out Please
vevalachris is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-03-2007, 11:48 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 416 Post(s)
Welcome to this forum! Some Fords come with a wiper module. I pulled one out from a Grand Marquis which had the same problem. Check Autozone's website for a schematic to see if you have this part.
BrooklynBay is online now   Reply With Quote
Old 12-04-2007, 11:26 AM   #3
Darrman
Waxahachie, TX
'92 Sport 4x4/2001 Sport
Vehicle Specs
Quoted: 0 Post(s)
Sounds like the same problems I had with my '92, turned out to be the wiper motor.
__________________
Darrman is offline   Reply With Quote
Old 12-04-2007, 11:49 AM   #4
Turdle
Move along people
nothing to see here
Turdle's Avatar
2000 Mounty
Vehicle Specs
Quoted: 686 Post(s)
The 2nd gens have a wiper park -run relay-and a wiper hi- lo relay--yes, 2 relays
You might check this out-- I'm not sure about the first gen's
__________________
Jon
9 mile skid, on a ten mile ride. Hot as a pistol but cool inside.
2000 Mountaineer
1998 Mountaineer "Turdle"-gone
1993 Convertible "Vitamin D Wagon" Sold also
Turdle is online now   Reply With Quote
Old 12-04-2007, 12:09 PM   #5
vevalachris
Marysville,wa
94 xploder
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I checked the fuse panel by the battery and didnt find any relay for the wipers. There are about 6 relays for other stuff but no wipers. If it was the motor wouldn't it not work all together? Doesn't the multi switch regulate the amount of current sent to the wiper motor with is only a one speed motor. The less current you send to the motor the slower the moter goes? If the multi switch is broke its just like turning it off and on. These are just my thoughts. I dont want to start replacing stuff without knowing for sure. New multi switch from schmucks is $120
Old 12-04-2007, 04:15 PM   #6
Darrman
Waxahachie, TX
Vehicle Specs
Quoted: 0 Post(s)
Well, thats kinda what I thought, so I replaced the MFS, did absolutely nothing to help. No, there is circuits in the motor housing itself and apparantly ocasionally they can go bad. Mine would only work in hi, and had no memory of where they were, turn it off and they would just stop wherever they were. If you turned the switch on and off in the delayed mode they would twitch.
However if you end up needing a MFS I still have my original, it was in great shape when I took it out.
__________________
Old 12-04-2007, 04:17 PM   #7
mikeinri
04 Explorer, 94 XLT (RIP)
Vehicle Specs
Quoted: 8 Post(s)
"I dont want to start replacing stuff without knowing for sure."
I hear that! Get a voltmeter, turn on the wipers and check the voltage at the leads on the motor. If you're getting the correct voltage with the switch turned on (low then high), it's the motor. If not, start working back toward the switch, fuses, etc.
Hope this helps.
Mike
mikeinri is offline   Reply With Quote
Old 01-06-2008, 10:26 PM   #8
vevalachris
Marysville,wa
94 xploder
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
OK...So its been a month and I have changed the mult switch and the wiper motor. Still only works on hi what else should I check?
Old 03-12-2008, 06:25 PM   #9
malsell
Horse Cave, KY
'94 XLT
Vehicle Specs
Quoted: 0 Post(s)
Exclamation fix
I don't know if you or anone else is still having this problem, but mine messed up and started doing the same thing about 2 weeks ago. To me, it didn't make any sense for it to be the switch because it wasn't intermitant. Most of the time a variable switch will only go dead in all positions, or one or two...Also, I knew from older style wipers (Mustangs, Thunderbirds and LTD's) the high setting is both windings of the motor, if the motor was bad, the high setting would work at half speed. My radio didn't start right up on Monday and I just dicided to see if i could hear anything. I heard a click inside the dash when I turned the wipers on. Inbetween the Steering Column and the heater controls and just above the annoying door chime is the control box. I broke this loose from the dash(as it was much easier than trying to take the screws out) and brought it in the house to inspect. The cover is easily removed and a printed circuit board is inside. There are several Resisters and Diods on the board as well as the Relay. I examined the resisters and diodes first due to the smell that came from the box, but all of the componets physically looked fine and from that smell, normally there will be physical signs of burning on the componet. I flipped the board over to examine the traces to see if it was something i missed. One of the solder joints was gone from the relay. I just simply re-soldered the connection and now they work like a charm. This board has simple componets. I will try to get a schematic of this board and post it at a later date.
malsell is offline   Reply With Quote
Old 03-12-2008, 09:30 PM   #10
vevalachris
Marysville,wa
94 xploder
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I actually figured out the problem. It was some sort of control box that was behind the ashtray. Found one at a pull-a-part. plugged it in and now everything works.
Old 03-12-2008, 10:27 PM   #11
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 416 Post(s)
Thanks for the update! Just for future reference, do you have part numbers on both modules?
Old 03-13-2008, 10:06 AM   #12
vevalachris
Marysville,wa
94 xploder
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I dont. Before I went to the junk yard I crawled under the dash and took a picture with my camera phone. Then I went to the junk yard looking for the same box in the same location. I noticed some had a metal module in the same spot but couldnt tell if that was a newer or older vehicle. The unit is held in by two torx screws that are in slotted holes and only needed to be partly unscrewed and then unpluged to take it out. If I only know this would of been my first step and not my last.
Old 03-13-2008, 10:26 AM   #13
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 416 Post(s)
I'm glad that it worked out. I did suggest the wiper module in post # 2.
Old 12-15-2008, 11:30 AM   #14
dansfordtruck
Vehicle Specs
Quoted: 0 Post(s)
my wipers where iced up to the windshild and turned the wipers on and didn't relize i didn't turn them off all the way. now the they only work on hi but are slow. the sprayer still work but wipers don't move unless i crank them up all the way. sometime it doesnt work at all and the next day it does but still not how they should. is it the module or what? 95 ford f 150 4.9L 4x4.
dansfordtruck is offline   Reply With Quote
Old 12-15-2009, 11:36 PM   #15
ForeverFixin
Vancouver BC
94 xlt
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Sorry to tell ya, but it sounds like you cooked the motor. If it makes you feel any better I have done the same thing being too lazy to brush heavy snow off the windshield and just trying to use the wipers to clear the windshield.
ForeverFixin is offline   Reply With Quote
Old 10-26-2010, 07:14 PM   #16
Caejxr
I need a less expensive hobby
'97 Turbo 4.0 OHV
Vehicle Specs
Quoted: 30 Post(s)
Just thought I'd add to the info on here... My wipers were having the lame issues...Do yourself a favor if you have a problem like this and check the relays first so you dont wind up going through the hassle of taking the shrouds off of your steering coloumn and removing a perfectly good multifunction switch and having to return a new one you spent 64 bucks on (stealership wanted $123.) Or worse, trying to replace wipermotors that are perfectly fine.
Anyhow.
Swap your horn relay(relay 1) (provided your horn works) with relay 2 (wiper run relay) and see if that fixed it. If that doesn't work try putting that horn relay into relay 3 (wiper high/low relay) spot. That should tell you which relay is goin out or if it's even a relay issue. Start with the easy fix first It could end up saving you time and money. (thats the relay numbers for a second gen fuse box though . I dunno if !st gen is the same.)
Caejxr is offline   Reply With Quote
Old 01-04-2011, 06:21 PM   #17
james87
walkerton, Va
94 xlt sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
Hey everyone, this is my first post. I have a question, has anyone obtained a picture of this said box that they can post? I looked under there and all I see is a bunch of stuff lol. Sorry I am sort of learning as I go but I am having this same problem. Thanks in advance if anyone can help me out.
james87 is offline   Reply With Quote
Old 01-07-2011, 11:47 PM   #18
trkmec
LYNNWOOD,WA
91 EXPLORER
Vehicle Specs
Quoted: 0 Post(s)
Quote:
sorry i do not have a picture at the moment , the control box on my 91 explorer is located behind the dash (inside the explorer) to the passenger
side of the steering column it has to very small screws that hold it in
place.after removing the screw slide the box toward the gas pedal and turn it
it should have biger numbers 17c476 on it , search that number on e-bay
and you can find a picture the number on the connector of the box
is e6eb-14a624-aa that is the coorect part number for my control
i think the other number is the housing number
hope this helps
trkmec is offline   Reply With Quote
Old 01-08-2011, 12:48 PM   #19
james87
walkerton, Va
94 xlt sport 4x4
Vehicle Specs
Quoted: 0 Post(s)
Thank you very much for the information. One more question, I have been told by a machanic that you have to take half the dash apart for this. Is this true?
Old 01-10-2011, 12:28 PM   #20
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Thanks for getting back with the resolution. It's what makes Forums work.
__________________
1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
Tony H is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
