How does a 4R70W filter hold in place? | Ford Explorer Forums
oldgun
Santa Clara, CA
'00 Eddie Bauer V8
2000 Explorer V8 5.0L.
Dropped the pan and pulled down the old filter. The new filter just does not hold in place no matter how hard I pushed it up. The part number of the new filter is F6AZ-7A098-A, cross referenced with FT105 on motorcraft.com
Does any one know how to fix the new tranny filter in place?
Did any one change fluid/filter on a 4R70W?
If you did, how did you put the filter firmly in place?
Thanks.
Good point-
when i changed my filter there were 3 different sized sleeves in the kit.
Is there a sleeve remaining inside the old filter's tube?
How do they compare?
I have a 4R70W in a 96 Lincoln, and the filter comes with two new O-rings. Be sure that the old O-rings are removed before installing the new filter. I put a little tranny fluid on the new O-rings and it has always pushed firmly and securely into place.
