| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Need for Speed! Explorer, Ranger, Mountaineer 4.0 - 4.6 - 5.0 Nitrous, Superchargers, Camshafts, Head Work, Stroker Kits... DRAG RACING. Explorers, Mountaineers and Rangers CAN move! |
Thread Tools |
#1 |
Trixi & Speed
Bremerton, WA
Hers:`93 XLT His `92 XL
How To: 4.0L OHV MAF upgrade....
I've been busy with a few projects.....
I finally installed my Custom Hood <---Link to the thread here on EF I finally installed the Intake Spacer (another link) I have had on the shelf for months But now I have upgraded my MAF too....I bought a 5.0L X MAF off ebay for $15.00 Here is what I got: ![]() ![]() Here is what I did to it: First things first....take the MAF electronics off the body ![]() I started by looking at the small plate off the back of the MAF...I can only think this was designed to created a little turbulance, slowing the air down a little around the sensor to get a good reading......I removed it. ![]() One that little plate was gone, It was time to get rid of that whole pillar in the middle of the MAF. Get a good hacksaw, take off the blade insert the blade into the MAF body, and re-attach the blade to the saw....saw away at the pillar ![]() ![]() Now you are almost done.... There is a little bit left on the bottom that SHOULD be removed if you have the ability. I used my airpowered die grinder. ![]() ![]() It literally took me all of 5 minutes to get to this point from when I first walked into my shop with the part in the box. Just for comparison sake, here is the stock 4.0L MAF opening compared to the 5.0L MAF: ![]() ![]() I can telll a difference with this MAF..... I love it.... I have a few other projects that I am working of for the X.......stay TUNED...(no pun intended)... Ryan __________________ 1992 White Ford Explorer XL 1993 Green Ford Explorer XLT 1992 Red Mazda Navajo XL |
| Sponsored Links (Less Ads) |
#2 |
Slinky+Escalator=Fun
Statesboro, GA
1993 Ford Explorer XLT
There's someone I haven't heard of in a while. It's about damn time somebody did an actual write up about this. Good job man, this will help a LOT of people... 5 star rating!!
This should definitely become a sticky for the First Generation Forum. The Cold Air intake, the flowmaster installation, and this writeup are probably the 3 most "wanted/needed" for us. Again, good job Ryan. |
#3 |
EF Vendor
Hueytown,Al
1998 Explorer Sport
Please don't think I am a naysayer but do you actually understand what the MAF meter does in a Ford vehicle? It commands all fueling,spark,load,trans shift schedules (on newer vehicles) and shift firmness (on new vehicles). I would be willing to be if you actually put your truck on a dyno that the vehicle lost hp and torque due to it being lean.. Furthermore the unit was engineered with the tonsil integrated into the body to reduce turbulance and reversion. I would like to see the MAF voltage (which would probably be all over the place). I could go into this even further but you get the idea. As far as a sticky. I wouldn't recommend it.-j
__________________ James 1998 Explorer Sport Turbocharged-RIP 8.270@84.53MPH IN THE 1/8TH @9PSI www.hensonperformance.com-call,text message or email for information on parts and services.SCT chips/programmers,HP Tuners,Diablo & UpRev (Nissan) Tuning,C&L,MAC,ASP,JBA & Gibson exhaust parts dealer! |
#4 |
Trixi & Speed
Bremerton, WA
This is a 1992( i.e. OBD1, Manual Trans X) the MAF does quite a bit..but not as much on a car this old..
Well, I have a dyno sheet from it's previous set-up, but won't get it dyno'd again until after I have done a few other things that will change the hp/tq numbers greatly....This mod on a totally bone stock X isn't something I would recommend....but on a modded motor like mine, I could tell a difference.. I think after I get done with all my mods, I'll throw the 4.0 MAF on there, and have it dyno'd...then do it again with this 5.0L...and I'm fairly positive it will make a slight difference in my favor with the 5.0 MAF on there.. Ryan __________________ 1992 White Ford Explorer XL 1993 Green Ford Explorer XLT 1992 Red Mazda Navajo XL |
#5 |
Statesboro, GA
The MAF conversion is mentioned in the First Generation forum under "How to build your own custom cold air intake" or something like that. A lot of people have done the conversion with positive results. Myself included. I'm pretty sure if that many people have done it and gotten good results, it's worth it...
http://www.explorerforum.com/forums/...=160528&page=2 around post 26 - 29 i want to say is where the discussion comes up.. Last edited by Blacksheep Josh; 05-23-2008 at 12:46 PM. Reason: link |
#6 |
EF Vendor
Hueytown,Al
1998 Explorer Sport
I custom tune EEC-iv vehicles all the time, actually 7 in the last 2 weeks. This mod will definately need a custom tune especially with a modded engine thus making it even leaner further supporting the necessity for a chip in that application. The laws of physics are still in effect. MAF turbulance isn't filtered just because it is EEC-iv. Hogging out or removing necessary components in a MAF meter is not recommended. Although EEC-iv isn't as dependent on the meter as EEC-V it still determines load,fueling and spark. Enough parameters are controlled to waste an engine. Especially if you don't have any logging to support that the modification is safe.-j
#7 |
Statesboro, GA
how do you tune our engines? i was under the impression they couldn't accept a chip or something other. so it is possible? link to site if possible?
(speaking about our first generation 4.0) |
#8 |
Trixi & Speed
Bremerton, WA
Josh....
Yes, tuning is totally possible on just about ANY vehicle... Some just allow more tuning than others. OBDI/EEC-IV doesn't have as many tuning parameters as the OBDII/EEC-V....but there is some power to be gained by doing it... I am getting another tune after I get some more work done... Ryan __________________ 1992 White Ford Explorer XL 1993 Green Ford Explorer XLT 1992 Red Mazda Navajo XL |
#9 | |
Statesboro, GA
Quote:
#11 |
Statesboro, GA
#12 |
Tulsa, Oklahoma
'92 XLT 4X4
Then again horse power and efficiency aren't mutually exclusive. Both goals are
basicaly the same: make as much power out of a givin amount of fuel as possible. __________________ -Matt To all those in uniform, past and present. Thank You.
#13 |
Trixi & Speed
Bremerton, WA
Having Multiple tunes gets expensive....but not impossible
But once you have a Performance Tune (92/93 octane req'd)...you'll never go to the 'lame' tune....even going to the store for milk will be fun.... Ryan __________________ 1992 White Ford Explorer XL 1993 Green Ford Explorer XLT 1992 Red Mazda Navajo XL |
#14 |
Statesboro, GA
So where do you get yours done? Or do you do them yourself? Is it a chip? I've seen bama chips and jet chips mentioned, but I'm at a loss as to what WILL work on the first generation.
also, i read in another thread about a man who does good port/polish work on intakes and throttlebodies, here's the thread if you're interested: http://www.explorerforum.com/forums/...d.php?t=216133 I've all ready emailed him about getting my Intake Manifold (after TB) done. I figure if it doesn't work, oh well... but if it does!!!... |
#15 |
Topless in winter
Humboldt, KS
1998 Mountaineer MX4 O/R
For tuning-
www.hensonperformance.com James is a site vendor- I need to take a look into my BBK throttle body and see if there is anything to be done there-- __________________ "I set my standards low, so I am not easily disappointed" 98 MX4 OFF ROADFOR SALE 93 with sky light Explorerforum license frames here |
#16 |
EF Vendor
Hueytown,Al
1998 Explorer Sport
You can tune a gen1 Explorer with a SCT chip. I have datalogging,etc. Unfortunately I have to be with the vehicle. It can be done. I also tune many Fox bodied Mustangs. If you are close to me I can tune you. If you would like to schedule time, just let me know. Chipping a Gen1 isn't impossible.
#17 |
Wannabe Elite Explorer
Great Falls, Montana
1991 XLT
what year that maf off of
#18 |
TOLEDO OHIO
2000 FORD EXPLORER SPORT
would this maf mod be possible with the stock 4.0l ohv mass air flow sensor? as far as cutting out that pillar in the middle.i got a sct programmer from henson performance.so i can data log all the info.would it really help?
__________________ http://www.cardomain.com/ride/2429989 4.0l ohv red taylor 8.8mm spiro pro wires, motorcraft platinum plugs,royal purple 5w-30 oil,k&n oil filter,valvoline synthetic brake fluid,red top optima battery under the hood.volant cai,helix throttle body spacer,sct 2 programmer/tune running 93 octane fuel,2 1/2" pipe ran into turbo 2 muffler with no cats,adjusted tps to .96volts,lowered 3" |
| Thread Tools | |
