Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks EF Arcade Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Tech - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo.
Reply
Thread Tools
Old 07-29-2007, 01:08 AM   #1
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Hers:`93 XLT His `92 XL
Vehicle Specs
Intake Manifold Spacer
...okay....
We've all heard for years that the Throttle Body Spacers don't work. They don't add enough volume to the intake manifold to make a difference. We know this.
We've ALSO heard over for years that the Intake Manifold Spacer on the 5.0L V8 DOES work....
I am making a 1/2" spacer to go inbetween the Upper and Lower intake Manifolds.
What, if any gains do guys think I'll see?
Thanks,
Ryan
__________________
1992 White Ford Explorer XL
1993 Green Ford Explorer XLT
1992 Red Mazda Navajo XL
Spdrcer34 is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-29-2007, 10:11 PM   #2
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
NOTHING?
Are you guys understanding what I'm doing here?
Ryan
__________________
Old 07-29-2007, 10:15 PM   #3
Turdle
Topless in winter
Humboldt, KS
Turdle's Avatar
1998 Mountaineer MX4 O/R
Vehicle Specs
What are you making this out of?
pictures please?
__________________
"I set my standards low, so I am not easily disappointed"
98 MX4 OFF ROADFOR SALE
93 with sky light
Explorerforum license frames here
Turdle is online now   Reply With Quote
Old 07-29-2007, 10:52 PM   #4
Turdle
Topless in winter
Humboldt, KS
Turdle's Avatar
Vehicle Specs
Hopefully you are making it with an insulating type material, like phenolic resin laminate-
__________________
93 with sky light
Old 07-29-2007, 10:54 PM   #5
shamaal
Friensdwood, Texas
91 Mazda Navajo
Vehicle Specs
You have the 4.0 OHV engine. Were you planning on putting the spacer on top of the fuel rail or under it? The existing gaskets are siliconized cardboard, I don't believe there is much heat transfer between them so your goal is the extra volume?
A reasonable discussion for the 4.0 SOHC can be found at:
http://www.explorerforum.com/forums/...old+spacer+ohv
The consensus was not much value predicted.
shamaal is offline   Reply With Quote
Old 07-30-2007, 02:25 AM   #6
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
The spacer has to go ON TOP of the rail assy, below the upper intake. It can't go BELOW the `rail....think about it!
The SOHC is a VERY efficient design.....but I'm talking about a OHV.
I am making it out of a sheet of 1/2" Phenolic.
Maybe I can make a Nitrous Plate similar to this one...but for the 4.0L OHV!
(kidding)
__________________
Old 07-30-2007, 11:18 AM   #7
quicklook2
lakewood, ohio
1994 exp 4X4 eddie bauer
Vehicle Specs
i am just not sure you will see any benefit from doing this.
quicklook2 is offline   Reply With Quote
Old 11-04-2007, 12:45 AM   #8
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
As some of you may have read in my other threads I made one out of a spare fuel rail....I don't know if anyone has done this before.
Has anyone tried this before on the 4.0L?...I know it works on the 5.0L.
I haven't installed it yet....but what do you think of it:
What type of gains do you suppose I will get with this? I will make on out of Phenolic next, now that I have a good pattern to cut it from.
Ryan
__________________
Old 11-04-2007, 09:18 AM   #9
JDraper
Stumblin' & Bumblin'
McVeytown, PA
JDraper's Avatar
'05 SCrew
Vehicle Specs
Whoops, didn't see this the first time around. I put one in on my Mach 1, and we dyno'd before and after. You most likely won't see any gains in either the max hp or max torque #'s, but what they really do is fatten the torque curve. The make the intake runners slightly longer, which helps the low end torque. When we installed the intake manifold spacer in my Mach, I crossed the 300 ft-lb level 600 rpms earlier than I did without the spacer, and it didn't affect the top end, so it effectively expanded my power band.
Many of the Mach 1 owners run them. I got mine from Paul's High Performance . His are made of aluminum, but there are other vendors now making them out of phenolic to help with keeping upper intake temperature down.
On the PHP website, they claim 4-8 hp increase, but the Mach 1 owners that have installed them have, in general, found that the peak increases are nil, it's the low end torque that it helps, especially if you have installed a cat-back that is less restrictive.
__________________
Moderator..Home Improvement/Explorer 911
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '05 F-150 Lariat SCrew, '08 Focus
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 11-04-2007, 09:09 PM   #10
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
Cool...thanks!
Ryan
__________________
Old 05-22-2008, 11:29 PM   #11
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
UPDATE:
Ryan
__________________
Old 05-23-2008, 09:59 PM   #12
seth247
Tulsa, Oklahoma
seth247's Avatar
'92 XLT 4X4
Vehicle Specs
if you feel gains I would be interested in buying one.
__________________
-Matt
Forest Green'92 XLT 4X4 302/4R70W
To all those in uniform, past and present. Thank You.
seth247 is offline   Reply With Quote
Old 05-24-2008, 01:52 AM   #13
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
After a commute to work, and back I can honestly say there is a bit more power sooner. I haven't taken the motor past 3500 yet, but I was able to break the tires loose in my N-1, 1-2 & 2-3, and at my previous 'normal' shift point of 2300-2500....on the way home I found that if I shift @ 1900-2100 I accelerate normally, with no bog...
I have 285/50-18's in the rear...so I have a bit more rubber back there than most any other 1st gen...
I am not selling these yet....I may do it later......
Ryan
__________________
Old 05-24-2008, 03:40 AM   #14
Beetle Bailey
Harrah Oklahoma
91'XLT and 93'XLT
Vehicle Specs
JDraper hit the nail right on the head. By raising the plenum you lengthen the runners. Therefore you are going to make better torque. But at the same time you should see a mild gain in economy. If you can keep your foot off the pedal. LOL Bailey.
Beetle Bailey is offline   Reply With Quote
Old 05-25-2008, 10:15 PM   #15
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
Yeah right....I can't keep my foot out of it....
I am going to try to go 1 tank with shifting @ a lower RPM, and see what mileage I could get...
Previously I was shifting @ 2500 for best economy....but I think I can lower that a little..before when I tried my 3-4 shift, it would bog @ less than 2200....I think I can try to shift @ 2100-2300..we'll see...
Ryan
__________________
Old 05-26-2008, 01:22 PM   #16
91exploreron37
Bartlett Tn
91 Eddie Bauer
Vehicle Specs
What did everything cost completed? Would you be interested in making a few more? I'd be interested in buying one for sure.
__________________
91 Eddie
Bunch 'O' Mods- 35's, winch, gears, blah blah
www.southernxplorer.com
91exploreron37 is offline   Reply With Quote
Old 05-26-2008, 01:29 PM   #17
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
Blacksheep Josh's Avatar
1993 Ford Explorer XLT
Vehicle Specs
Quote:
seconded.
__________________
"Thunder" Registry
"You can hear me when I'm coming" - Yung Joc
Blacksheep Josh is offline   Reply With Quote
Old 06-20-2008, 01:13 AM   #18
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
I have something in the works for getting these made...
Nobody say anything that is involved in this process....I am trying to keep costs down.
Ryan
__________________
Old 06-20-2008, 11:31 AM   #19
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
I had one on my old 2.9L and it works! The metal upper intake would barely get warm, it used to get so hot you could cook breakfast!
On the OHV 4.0L only those with metal upper intakes are going to see any gains...
I believe a colder intake charge (and the price of metal) is why all manufacturers eventually went to plastic upper plenums.
I have a 1" FMS spacer on my 5.0L and I love it.
Good work on your 4.0L, pretty simple upgrade and should work well in dropping the intake air tempature slightly.
Remember you are only as good as your smallest bottleneck
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is online now   Reply With Quote
Old 06-20-2008, 01:06 PM   #20
Spdrcer34
Trixi & Speed
Bremerton, WA
Spdrcer34's Avatar
Vehicle Specs
410....If you'll notice, the first one I made and installed on my personal vehicle is made from Aluminum.....I noticed a HUGE improvement....
I'd like to see if I can get more improvement with a Phenolic one...We'll see
Ryan
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
