Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Body Work & Detailing
Notices
Body Work & Detailing Waxing washing, wheel cleaning and body work. This is the place to discuss those topics.
Headlight Restoration
Reply
Thread Tools
Old 07-22-2010, 06:26 PM   #1
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
(Original Poster)
How To: Headlight Restoration
I have tried many different products to restore the plastic headlights. Nothing really worked well. There are many good threads/posts here read over many times. Thanks to everyone for posting and answering my questions. My buddy asked me about restoring the headlights on his 2001 minivan. I ended up using the 3M Headlight Restoration System. I picked it up at AutoZone for $20.
Be sure to check out my other write-ups:
How To: Replace Blend Door Actuator in 3rd Gen Ex
How To: Remove/Replace 3rd Gen Door Panel
How To: Install Signal Mirrors On 3rd Gen Ex
How To: Replace Multifunction Switch in 3rd Gen Ex
How To: Paint Rear Pillar Trim
How To: Replace 3rd Gen Ambient Air Temperature Sensor
How To: Test a Relay
How To: Remove/Replace 3rd Gen Center Console
It comes with the following:
6 - 500 Grit Sanding Pads
4 - 800 Grit Sanding Pads
1 - 3000 Grit Wet Sanding Pad
1 - Foam Buffing Pad
1 - Backing Plate
1 - Pack of Rubbing Compund
In addition to the kit you will need the following:
Painter's Tape - to mask off the area to prevent sanding surrounding areas
Spray Bottle filled with ordinary water
Drill (1200-1600 RPM), I used my Dewalt cordless drill set on 2
The kit has excellent instructions so I won't bore you the details. Basically you sand the "damaged" layer off and buff it to a shine. Now on to the results:
Here is the before shots:
The sanding process:
After using the three 500 grit pads:
After using the two 800 grit pads:
After using the 3000 grit wet pad:
After using the rubbing compound, the finish product:
The headlights look like new. We polished the lights when we were done to help protect against UV rays. I told my buddy to polish the headlights every time he washes the minivan. This kit might be the best $20 I ever spent on detailing!!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is online now   Reply With Quote
Old 07-22-2010, 06:35 PM   #2
FloridaState
Tallahassee, FL
'97 XLT 4x4
Vehicle Specs
I need to get that. I bought some cheapy Turtle Wax kit for like $5 last month when I clay-bar'd my X, but the headlights are starting to fog up again.
Headed back home in August for a few weeks, I'll try and give it a whirl!
Thanks for the all the info.
FloridaState is offline   Reply With Quote
Old 07-22-2010, 06:39 PM   #3
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
(Original Poster)
It's absolutely amazing how good this works. I have used all the cheap kits too. This is the real deal. - Rondo
__________________
Old 07-22-2010, 06:48 PM   #4
Flounder
Elite - Owns 10,000 Marbles
Pennsylvania
Flounder's Avatar
'04 Sport Trac
Vehicle Specs
Great results!
Flounder is offline   Reply With Quote
Old 07-22-2010, 09:36 PM   #5
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by Flounder View Post
Great results!
Thanks Flounder. I wish they had this, or I knew about it, years ago!!
__________________
Old 07-24-2010, 12:42 PM   #6
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
(Original Poster)
Round Two!
Another buddy of mine saw how the minivan came out and wanted me to do his wife's '02 Jeep. These were real bad and required 1 kit per light. $40 vs the $300+ they were quoted to replace the lights, not bad! Here are the results:
Before:
After:
__________________
Old 07-24-2010, 06:47 PM   #7
GRNMACHINE
IL
95 Sport 4x4
Vehicle Specs
Unbelievable! Makes me want to return the Meg's kit.
__________________
95 Sport 4x4, 3.73, tt/shackles, K&N FIPK, 33X12.50X15 BFG T/A, 15x10 DC-1's, Pro Comp ES9000 shocks, Flowmaster Catback, ARB OME Leaf Springs, 2" BODYLIFT
"Thy shall Not Leaveth Thou Chariot Stocketh" Explorer 2nd Genesis
GRNMACHINE
GRNMACHINE is offline   Reply With Quote
Old 07-24-2010, 07:48 PM   #8
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
(Original Poster)
Quote:
It's incredible. Comes with detailed instructions. Follow the instructions and you will be good to go!!
__________________
Old 08-11-2010, 03:51 PM   #9
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
For those that need to do this fast (headlight restoration) I used the meguiars plastx last night. I needed to do it quickly last night so Yolanda could use the honda today.. I spend 2 minutes per side.. Here is a pic after I finished the 1st light..
I don't know how long it will last but it worked better than I expected. Now we'll see how long it actually lasts..
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is online now   Reply With Quote
Old 08-11-2010, 11:06 PM   #10
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
(Original Poster)
~Mark
Wow, that came out great! Did you have to apply a lot pf pressure? Keep us posted on how long it lasts.
__________________
Old 08-11-2010, 11:10 PM   #11
Maniak
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Wasn't that much pressure. I used my right hand which I can't put lots of pressure with (wrist has a screw in it). I only spent about 2 minutes per side.. Was rub on, wipe off.. and that was it.
I'll report back when I need to do it again as that is the Daily driver..
~Mark
__________________
Old 08-12-2010, 03:01 AM   #12
Joe Dirt
Living in Greenland
Holland, MI
Joe Dirt's Avatar
'00 V8 XLT
Vehicle Specs
Nice work! I've been using 3M Finish Restorer for a while, but the PlastX is as good- nice quick way to do it without sandpaper, although the sandpaper kits can get more of the pits out.
Whatever you use, be sure to keep them protected as the stuff you scuffed off was the old UV protectant layer, so they will fog/yellow much quicker than before. I'd toss some on at least once a month. On my SHO's I did it every other wash just to be safe...
Nice work!
__________________
Quote:
Originally Posted by FIND View Post
Also, every time you use an apostrophe for a plural, Jesus kills a kitten.
My registry
Joe Dirt is offline   Reply With Quote
Old 08-12-2010, 07:51 AM   #13
Scott B.
Elite Ranger
GA
Scott B.'s Avatar
'93 Ranger XLT, 06 FX4 L2
Vehicle Specs
Regarding protection, I just installed Clear Mask on the lights on my '06. It is a plastic film, designed to protect the lights from getting chipped and cracked.
Installation was straightforward.
While it will protect the lenses from getting cracked from stones, I don't know what it will do in regards to fogging. We shall see.
__________________
Scott
NRA Life Member
EMT-I, UFWDA Chief Instructor
1993 Ranger XLT V8, Modified
2006 Ranger FX4 Level II, Modified
Scott B. is offline   Reply With Quote
Old 08-29-2010, 07:34 PM   #14
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
(Original Poster)
Scott, Clear Mask appears to be unavailable in my area. Where did you get yours? Did you get a headlight kit or get it in sheets and cut it yourself?
Thanks, Rondo
__________________
Old 08-30-2010, 06:16 PM   #15
Scott B.
Elite Ranger
GA
Scott B.'s Avatar
Vehicle Specs
Quote:
Thanks, Rondo
Click on the link - I ordered from them directly.
I got a headlight kit - 2 each of headlights, corners and fog lights.
__________________
Scott
NRA Life Member
Old 12-15-2010, 10:48 PM   #16
jake122288
Pleasantville, iowa
1994 4-door xlt 4x4
Vehicle Specs
I've used it before on plastic...but not the glass... i'll have to read into that!
and whoops i posted on the wrong thread!!! hahahah so i'll change this.... does anyone know if it would work on an all glass lense of my aux lights?
jake122288 is offline   Reply With Quote
Old 12-15-2010, 11:34 PM   #17
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
From what I've read, the plastic protective film, of any brand, is bad to use as a headlight lens protector since it insulates the plastic lens, preventing the airflow from cooling it directly, and eventually causes multiple hairline cracks throughout the lens surface. This appears to have happened on everything from economy cars to high end exotic rides.
I would think it wouldn't do the same on glass, but it still might, or at least have some insulating effect and might cause the lamp assembly itself to get hotter than usual, especially on fog lights where the lens is the only part exposed to airflow.
At this point I've decided against any protective film, it seems more hassle than it's worth, especially for the cost and possibilities of surface damage. Better protection for headlights would probably be clear plastic covers. They are now rather inexpensive too since the trend of smoke colored ones and the clear ones to be painted seems to have gone.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is offline   Reply With Quote
Old 12-16-2010, 12:28 AM   #18
FIND
Likes Math!
Vermillion, SD
FIND's Avatar
99 XLT V8 AWD
Vehicle Specs
Don't you guys clearcoat headlights or add a UV coating after you restore them? It would make the restoration last longer, they come from the factory with a scratch resistant UV coating on the outside of the lens.
__________________
I strongly abide by the motto, "Safety third."
Quote:
Originally Posted by NICE59FORDF100 View Post
Dont forget numbers. Teacher Ladies LOVE numbers
FIND is offline   Reply With Quote
Old 12-16-2010, 01:18 PM   #19
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
Thank you BigRondo for the product review. I used it in making my decision of what to use a few months ago and I can't help but share my results. Mainly because it looks so much better!
Before:
After:
I did not use any type of sealant to replace the UV protection coat that is sanded off. It has been four months and the lenses are still clear and not discolored. I did however look into UV protection coating quite a bit before I did this and came upon this thread. If you read through the whole thing you'll find a good deal of info. The main idea is to use Helmsman Spar Urethane as a coating mixed with mineral spirits as a solvent to apply it after you are done wet sanding and polishing the lenses.
__________________
There is wisdom to be found in the counsel of many.
OneLever is offline   Reply With Quote
Old 12-16-2010, 01:33 PM   #20
2TimingTom
Highlands Ranch, Colorado
'97 XLT
Vehicle Specs
I need to look into this as well. Thanks.
__________________
1997 XLT SOHC Auto 4wd 132,000 miles
Explorer registry
Also in the garage: 2012 Escape Limited 4wd V6 auto AND 2004 Saturn VUE 4 cylinder 5 speed
Colorado 4x4 Adventures
2TimingTom is online now   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
