| Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Virginia
1997 Ford Explorer sport
I've recently lost reverse, and a trusted mechanic friend of mine suggested it could be a solenoid. I changed the filter & fluid; also, there were no signs of anything loose or coming apart. I was just wondering if purchasing a new valve body, with all new solenoids could help my problem. Any help is greatly appreciated. Thank you.
#2 |
VA
1997 XLT 4.0 SOHC 4WD
It might be a problem with the reverse servo, or the low/reverse band. Do you have engine braking in manual 1st gear? Also, how many miles do you have on your transmission? Do some searching here, and in the transmission sub-forum, for 5R55E no reverse. Lots of reading to do.
I would imagine a valve body rebuild would not be a bad thing for a transmission of that age (the valve bores are prone to wear, as is the EPC solenoid) , but to say that would cure the problem, I doubt it. That is a fairly complicated transmission, with MANY possible causes, so I would not just put parts on without a more thorough diagnosis. Do some more research. |
#3 |
Virginia
The transmission has around 230xxx miles on it. I have engine breaking in manual first, and also the o/d light flashes sometimes causing a rough shift into second and third.
#4 |
VA
Get the transmission codes read. Do you have Torque Converter Clutch lock-up at highway speeds?
#5 |
Virginia
It does fine at highway speeds. When the overdrive lights not blinking its shifts like a brand new trans but when it does blink it shifts hard into second and third.
| Tags |
| 1997, explorer, reverse, reverse solenoid, transmission |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 01 Ford Explorer Sport Trac 4x4 "911" fuel pump problem | Sramsey232 | 2001-2005 Explorer Sport Trac | 0 | 03-01-2011 09:57 PM |
| '95 4x4 XLT Control Trac Explorer Transfer Case Problem | Dougith | Explorer & Ranger Transmissions, Transfer Cases, & Differentials | 3 | 08-01-2008 01:47 PM |
| 2006-2007 Explorer Sport Trac 4x4 | modette | Stock 2002 - 2005 Explorers | 1 | 08-27-2006 03:12 PM |
| Thread Tools | |
