Harleysofttail06
- December 30, 2012
- Amherst Ohio
- 1997 Ford Explorer
Hello the one i have is the 1997 but says 1996 on the door
97-01 4-door and 96-00 Sports
Your control knob should say 4auto, 4high, 4low.
First, we need to narrow it down to a transfer case issue, or a front axle issue.
I have checked the fuses all of them i put a new trasfercase motor on and just put two new hubs on last night and still the front end will not engage i have jacked the front end up and turned the wheels the turn the oppeset way but sometimes when turning it one wheel stops turning when you spin the drive shaft they both turn and go the oppest way the 4 wheel high and low light will come on when switched just don't understand why the front won't lock in any help would be great:exp:
