- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
i just finished putting on a 75mm BBK throttle body (that i bought used), and have had some problems. first, the truck is a 98 sport with a 5L, and a m90 supercharger on it.
when i did the throttle body, i also make a bigger throttle body elbow as well (3 1/2 inch), and modded the shaft for the butterfly by cutting the part of the shaft that faces you when its closed. now that is on, here are the problems. this thing whistles and hums like mad. its already driving me nuts, and its only been a day, i am having some idle issues with it, and now have a P1506 code (Idle Air Control Over Speed Error),
at first i thought it was the IAC, and lucky for me, i had a bran new one kicking around. tried it, no luck. took the elbow off thinking that the flanges were warped (checked with a strait edge), and they are flat. anyone else have these problems at all?
