Update for 2005 Owners-Seat Belt Chime Alarm Shut Off
ITs in the manual for your explorer - Went through the manual of my 04 and instructions say ....
ignition off
doors closed
headlights off
buckle and unbuckle 3 times ending unbuckled
turn on headlights
turn off headlights
seatbelt light will light for 3 seconds and go off
within 7 seconds buckle and unbuckle seatbelt once more
seatbelt light will flash
worked for me.. did it about 3 yrs ago.
Ford likes to screw with us Explorer owners I guess, because I found out the above seat belt chime shut off method for 2004 Explorers must change year to year. So here is the instructions for owners of 2005 Explorers that do not have their vehicles owners manual anymore and need a little help:
The pages in the 2005 owners manual for the instructions on how to "deactivate the seat belt minder/chime" can be found on pages 135 & 136 if you still have the owners manual. The steps also differ a little from the ones above posted by "Curtis" which are for 2004 Explorers.
The 2005 Steps go as follows:
Vehicle turned off
Parking Brake set
Gear shift in PARK
Ignition switch in OFF position
All doors closed
Safety Belt Unbuckled
Parking/Headlamps in OFF position (Note: If you have auto headlamps, turn off the auto headlamp feature)
Now begins the Deactivation Procedure:
#1: Turn ignition switch to RUN position
#2: Wait for seat belt warning light on dash to turn off (takes a minute or so)
:Steps 3 thru 5 must be completed within 60 seconds
#3: At a moderate speed, buckle then unbuckle the seat belt 3 times, leaving it in the UNbuckled position
#4: Turn Parking/Headlamps ON then Off once
#5: At moderate speed, buckle then unbuckle the seat belt, leaving it in the unbuckled position
: after step 5 is done, seat belt warning light will light up for 3 seconds
#6: Within 7 seconds of the seat belt warning light turning off, at moderate speed, buckle and unbuckle the seat belt once leaving it unbuckled
: This will deactivate the seat belt minder chime if it was currently enabled on your vehicle prior to doing these steps
#7: Confirmation of deactivation of the seat belt minder chime is provided by the seat belt warning light flashing 4 times per second, for 3 seconds or 12 warning light flashes. (Note: when the seat belt warning light is done flashing and turns off completely, you are done)
If you want to re-activate the seat belt minder chime in the future, the steps are the same as above, but with a few extra flashes of the seat belt warning light from Step #7 Confirmation.
Like others have said, these steps sound ridiculous to do and they are, but they work, I just did it on my 2005 Explorer and no more annoying seat belt chime. One down and few more annoying chimes to go!
One other thing! When you go to start the vehicle up and drive it for the first time after doing this, you'll notice the seat belt icon light will light up on the dash, don't freak out, it won't chime at all and it will disappear in about 2 minutes of run time. It will do this each and every time you start up the vehicle, but no more warning chime.
