13interceptor
- May 14, 2017
- Huntington ny
- 2013 interceptor utility
How do i add photo of alignment sheet
Dead Link Removed Or find a 3rd party hosting site to link to (not photobucket).How do i add photo of alignment sheet
As I've mentioned, and if you would focus on the actions I mention, you might find resolution. In addition, there are a lot of parts in the front and rear suspension, over and above what you replaced. If you want to make progress, review what I wrote above. I've given you simple things to check. More messages is not going to get you any closer to a fix unless you go get your hands dirty.
An alignment if set correctly shouldn't change drastically under panic stops. If you have a suspension component moving due to a bad bushing, it could cause a pull. Uneven brake pressures will do it too. Again, the ball is in your court.
Right front castor shows in RED 2.3. Not sure what that means ????? I will post full alignment sheet when I figure this out
Anything in red is not good. Indicates it is out of alignment.Right front castor shows in RED 2.3. Not sure what that means ????? I will post full alignment sheet when I figure this out
On my printout there is no mention of "castor" only 'Camber'. Camber and Toe adjustments is what an alignment is all about. I think you should take it to the dealer or another alignment shop and have this checked/addressed before going any further. We seem to be going in circles here.Can caster be adjusted at all ? Can this indicate a bent frame ?
Thank you for taking out the Elite membership.It actually is driving Better since this last alignment. I’m trying to post the entire sheet from alignment. I have to upgrade my account . Will post shortly. I appreciate all the help
