Subscribing. I have the exact same problem, right down to more noise up and less noise down a hill.
I've replaced lower bjs, upper pass control arm, new tires mounted and balanced, alignment, replaced pinion bearings and carrier bearings, and I've dropped my front driveshaft to eliminate that from the issues. Still have vibration over 65. Interesting how everyone says 65, that seems to be the problematic speed across the board. U-joints are tight, though I might replace them just for kicks and giggles. I just bought the truck a month ago with 175000 on the odo, and have no idea what service was performed and at what time.
Seemed to have no bearing problems, at least not when I spun the wheels individually while working on the front and rear end. I do have a very small thickness double rusted groove in my pass side rear rotor, still got plenty of wear left on the caliper though. Probably something stuck on the inside of the caliper that wore it down - or maybe sub-par calipers. Absolutely no rubbing though, no heat after driving or anything.
