- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
"e.g. use the converter bolts to pull the converter to the flexplate"
Ut oh, what did I do wrong? This is how my A4LD and 4r70w have been installed, this is how I was told to install them both by the builders.
Stab the converter completely into the pump, raise trans, stab trans, bolt bellhousing to engine, then converter slides forward when you rotate the crank and tighten down the converter to flywheel bolts.
is this no bueno? seems to have worked fine??
