- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
My ignition cylinder popped apart when I closed the door of the van as I was leaving a job! The front piece which turns when you turn the key completely broke off. I could still turn the cylinder with the key, but the cylinder sticks, and has to be turned manually back from the crank position to the run position.
My ignition switch is also acting up. A lot of times when I turn the key, the starter won't crank unless I play with the ignition key. It has to be turned on & off. I saw cylinders & switches going pretty cheap on EBay. It might be worth getting these parts before I get stuck, and can't start it.
