Here is my situation on my A/C not blowing through the front vents. I have checked all vacuum lines from the actual a/c switches all the way to the vacuum resevoir. I actually replaced the vacuum resevoir with a replacement from a junkyard just in case it was the problem (negative on that). I have a few questions for you guys to help me narrow down the problem!
-If I were to pull off either one of the lines at the vacuum resevoir, should I be able to feel/hear suction in the line?
-Where does the initial vacuum pressure come from?
-Is there a way to test whether or not my car is even creating vacuum pressure for the a/c lines to make the vacuum motors/actuators work?
-What is needed to make the a/c come through the dash vents? (a certain vacuum motor or vent door?)
I've noticed that when I move the vacuum motor's arms to make the recirculating door open is does not change any of the vents blowing air; But I did push the arm on the vacuum actuator for the floor vents and air started blowing out of the floor vents. So wouldn't that mean I certainly have a vacuum leak because that actuator is not receiving vacuum pressure to make the motor work?
Sorry for a long post but I have been reading everything on here about A/C problems and haven't been able to fix it.
